跳转到主内容
HP Pavilion g7-1365dx RTC Battery Replacement
你所需要的
  1. HP Pavilion g7-1365dx RTC Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • To prevent injury, make sure the laptop is powered off before removing the battery.
    • Flip the laptop so that it is upside down and opens away from you. This exposes the battery, it will be centered at the bottom of the laptop .
    • Push the switch above the battery towards the center of the laptop .
  2. HP Pavilion g7-1365dx RTC Battery Replacement: 步骤 2 中的图像 1,1
    • While pushing the switch, lift the battery by the side closest to the switch up and away from the laptop.
  3. HP Pavilion g7-1365dx RTC Battery Replacement, Service Door: 步骤 3 中的图像 1,2 HP Pavilion g7-1365dx RTC Battery Replacement, Service Door: 步骤 3 中的图像 2,2
    • Using a Phillips size 0 screwdriver, unscrew the 2 Phillips screws.
    • Use the opening tool around the edges of the service door to loosen it and remove it.
  4. HP Pavilion g7-1365dx RTC Battery Replacement, RTC Battery: 步骤 4 中的图像 1,2 HP Pavilion g7-1365dx RTC Battery Replacement, RTC Battery: 步骤 4 中的图像 2,2
    • Disconnect the RTC battery power cable from the system board.
    • Remove the RTC battery from the system board. (The RTC battery is attached to the system board with double-sided tape.)
    • Slide the RTC battery out from under the surface of the base enclosure.
结论
Derrick Manu
于03/18/19注册
245 声望
创作了2篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 27
总计 1,594
