跳转到主内容
HP Pavilion g7-1365dx RAM Replacement
你所需要的
  1. HP Pavilion g7-1365dx RAM Replacement, Battery: 步骤 1 中的图像 1,1
    • To prevent injury, make sure the laptop is powered off before removing the battery.
    • Flip the laptop so that it is upside down and opens away from you. This exposes the battery, it will be centered at the bottom of the laptop .
    • Push the switch above the battery towards the center of the laptop .
  2. HP Pavilion g7-1365dx RAM Replacement: 步骤 2 中的图像 1,1
    • While pushing the switch, lift the battery by the side closest to the switch up and away from the laptop.
  3. HP Pavilion g7-1365dx RAM Replacement, Service Door: 步骤 3 中的图像 1,2 HP Pavilion g7-1365dx RAM Replacement, Service Door: 步骤 3 中的图像 2,2
    • Using a Phillips size 0 screwdriver, unscrew the 2 Phillips screws.
    • Use the opening tool around the edges of the service door to loosen it and remove it.
  4. HP Pavilion g7-1365dx RAM Replacement, RAM: 步骤 4 中的图像 1,2 HP Pavilion g7-1365dx RAM Replacement, RAM: 步骤 4 中的图像 2,2
    • Use your fingers to simultaneously pull apart both tabs holding the module.
    • The memory module will pop up once the tabs are pulled so that it can be removed.
  5. HP Pavilion g7-1365dx RAM Replacement: 步骤 5 中的图像 1,1
    • Directly pull out the memory module as shown.
结论
Rafal Szmyd
于03/22/19注册
181 声望
创作了2篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 13
总计 318
