跳转到主内容
HP Pavilion g7-1365dx Optical Drive Replacement
你所需要的
  1. HP Pavilion g7-1365dx Optical Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • To prevent injury, make sure the laptop is powered off before removing the battery.
    • Flip the laptop so that it is upside down and opens away from you. This exposes the battery, it will be centered at the bottom of the laptop .
    • Push the switch above the battery towards the center of the laptop .
  2. HP Pavilion g7-1365dx Optical Drive Replacement: 步骤 2 中的图像 1,1
    • While pushing the switch, lift the battery by the side closest to the switch up and away from the laptop.
  3. HP Pavilion g7-1365dx Optical Drive Replacement, Service Door: 步骤 3 中的图像 1,2 HP Pavilion g7-1365dx Optical Drive Replacement, Service Door: 步骤 3 中的图像 2,2
    • Using a Phillips size 0 screwdriver, unscrew the 2 Phillips screws.
    • Use the opening tool around the edges of the service door to loosen it and remove it.
  4. HP Pavilion g7-1365dx Optical Drive Replacement, Optical Drive: 步骤 4 中的图像 1,3 HP Pavilion g7-1365dx Optical Drive Replacement, Optical Drive: 步骤 4 中的图像 2,3 HP Pavilion g7-1365dx Optical Drive Replacement, Optical Drive: 步骤 4 中的图像 3,3
    • Using the Phillips size 00 screwdriver, unscrew the 4.7 mm screw that holds the optical drive.
    • Use the opening tool to slide the drive out the side of the laptop to remove it.
结论
Colin Klaes
于03/21/19注册
259 声望
创作了3篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 144
