跳转到主内容
HP Pavilion g7-1365dx Keyboard Replacement
你所需要的
  1. HP Pavilion g7-1365dx Keyboard Replacement, Battery: 步骤 1 中的图像 1,1
    • To prevent injury, make sure the laptop is powered off before removing the battery.
    • Flip the laptop so that it is upside down and opens away from you. This exposes the battery, it will be centered at the bottom of the laptop .
    • Push the switch above the battery towards the center of the laptop .
  2. HP Pavilion g7-1365dx Keyboard Replacement: 步骤 2 中的图像 1,1
    • While pushing the switch, lift the battery by the side closest to the switch up and away from the laptop.
  3. HP Pavilion g7-1365dx Keyboard Replacement, Service Door: 步骤 3 中的图像 1,2 HP Pavilion g7-1365dx Keyboard Replacement, Service Door: 步骤 3 中的图像 2,2
    • Using a Phillips size 0 screwdriver, unscrew the 2 Phillips screws.
    • Use the opening tool around the edges of the service door to loosen it and remove it.
  4. HP Pavilion g7-1365dx Keyboard Replacement, Keyboard: 步骤 4 中的图像 1,2 HP Pavilion g7-1365dx Keyboard Replacement, Keyboard: 步骤 4 中的图像 2,2
    • Remove the 4.7 mm screw that secures the keyboard to the computer using the Philips 00 screwdriver.
  5. HP Pavilion g7-1365dx Keyboard Replacement: 步骤 5 中的图像 1,1
    • Rest the laptop on its side so the optical drive is pointing up.
    • Insert the hex 2.0 screwdriver into the screw hole that had the 4.7 mm screw, press till the keyboard pops out.
  6. HP Pavilion g7-1365dx Keyboard Replacement: 步骤 6 中的图像 1,1
    • Turn the laptop right side up, facing you. Use the opening tool to help pull the keyboard towards you.
  7. HP Pavilion g7-1365dx Keyboard Replacement: 步骤 7 中的图像 1,1
    • Unplug the keyboard ribbon cable and remove the keyboard.
结论
jonathan Rodriguez
于03/26/19注册
109 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 16
总计 466
