跳转到主内容
HP Pavilion g7-1150us RAM Replacement
你所需要的
  1. HP Pavilion g7-1150us RAM Replacement, Battery: 步骤 1 中的图像 1,2 HP Pavilion g7-1150us RAM Replacement, Battery: 步骤 1 中的图像 2,2
    • Slide the battery removal switch towards the center of the laptop until the battery pops out.
  2. HP Pavilion g7-1150us RAM Replacement: 步骤 2 中的图像 1,1
    • Remove the battery from the computer.
  3. HP Pavilion g7-1150us RAM Replacement, Surface Panel: 步骤 3 中的图像 1,1
    • Unscrew the two 4mm Phillips #0 screws found in the surface panel.
  4. HP Pavilion g7-1150us RAM Replacement: 步骤 4 中的图像 1,2 HP Pavilion g7-1150us RAM Replacement: 步骤 4 中的图像 2,2
    • Using the spudger, pry the surface panel off starting from the side where the battery was located.
    • Pry the remainder of the panel off by sliding the spudger underneath the panel and gently lifting.
    • Aim for the corners of the panel while using the spudger to methodically remove it without damaging it.
  5. HP Pavilion g7-1150us RAM Replacement: 步骤 5 中的图像 1,1
    • Lift the pried surface panel off of the computer.
  6. HP Pavilion g7-1150us RAM Replacement, RAM: 步骤 6 中的图像 1,1
    • Push outwards on the two clips holding the RAM in place.
  7. HP Pavilion g7-1150us RAM Replacement: 步骤 7 中的图像 1,2 HP Pavilion g7-1150us RAM Replacement: 步骤 7 中的图像 2,2
    • Slide the RAM out of its position in the opposite direction of the battery removal switch.
结论
Kyle Dinunno
于03/20/19注册
377 声望
创作了3篇指南
团队
UMass Dartmouth, Team S6-G3, Peak Spring 2019 UMass Dartmouth, Team S6-G3, Peak Spring 2019 的会员
UMASSD-PEAK-S19S6G3
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 14
总计 422
