跳转到主内容
HP Pavilion g7-1150us Optical Drive Replacement
你所需要的
  1. HP Pavilion g7-1150us Optical Drive Replacement, Battery: 步骤 1 中的图像 1,2 HP Pavilion g7-1150us Optical Drive Replacement, Battery: 步骤 1 中的图像 2,2
    • Slide the battery removal switch towards the center of the laptop until the battery pops out.
  2. HP Pavilion g7-1150us Optical Drive Replacement: 步骤 2 中的图像 1,1
    • Remove the battery from the computer.
  3. HP Pavilion g7-1150us Optical Drive Replacement, Surface Panel: 步骤 3 中的图像 1,1
    • Unscrew the two 4mm Phillips #0 screws found in the surface panel.
  4. HP Pavilion g7-1150us Optical Drive Replacement: 步骤 4 中的图像 1,2 HP Pavilion g7-1150us Optical Drive Replacement: 步骤 4 中的图像 2,2
    • Using the spudger, pry the surface panel off starting from the side where the battery was located.
    • Pry the remainder of the panel off by sliding the spudger underneath the panel and gently lifting.
    • Aim for the corners of the panel while using the spudger to methodically remove it without damaging it.
  5. HP Pavilion g7-1150us Optical Drive Replacement: 步骤 5 中的图像 1,1
    • Lift the pried surface panel off of the computer.
  6. HP Pavilion g7-1150us Optical Drive Replacement, Optical Drive: 步骤 6 中的图像 1,1
    • Use the screwdriver to remove the 4mm Phillips #0 screw holding the optical drive in.
  7. HP Pavilion g7-1150us Optical Drive Replacement: 步骤 7 中的图像 1,1
    • Use your fingers to grab the optical drive.
  8. HP Pavilion g7-1150us Optical Drive Replacement: 步骤 8 中的图像 1,1
    • Pull out drive completely.
结论
Cierra Sheerin
于03/25/19注册
97 声望
撰写一个指南
团队
UMass Dartmouth, Team S6-G3, Peak Spring 2019 UMass Dartmouth, Team S6-G3, Peak Spring 2019 的会员
UMASSD-PEAK-S19S6G3
3 名成员
创作了5篇指南
2条评论
What do you do when the DVD drive will NOT slide out? That’s my problem. There’s no disk inside; the unit is simply stuck shut. Now what do you do?
paulwrites - 回复
For me, the DVD drive connection had, what I think was soda, inside of the port and it acted like a sort of glue so brute force may be the option.
After a deep cleaning of the connections, it worked like new.
Dylan Dopp -
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 17
总计 434
