跳转到主内容
HP Pavilion g6-2228tx Optical Drive Replacement
你所需要的
  1. HP Pavilion g6-2228tx Optical Drive Replacement, Battery: 步骤 1 中的图像 1,2 HP Pavilion g6-2228tx Optical Drive Replacement, Battery: 步骤 1 中的图像 2,2
    • Push the battery latch to the left to release the battery.
    • Remove the battery from the device.
  2. HP Pavilion g6-2228tx Optical Drive Replacement, Hard Drive: 步骤 2 中的图像 1,2 HP Pavilion g6-2228tx Optical Drive Replacement, Hard Drive: 步骤 2 中的图像 2,2
    • Use a Phillips #0 screw driver to loosen the screw. The screw will not detach from the cover.
  3. HP Pavilion g6-2228tx Optical Drive Replacement: 步骤 3 中的图像 1,3 HP Pavilion g6-2228tx Optical Drive Replacement: 步骤 3 中的图像 2,3 HP Pavilion g6-2228tx Optical Drive Replacement: 步骤 3 中的图像 3,3
    • Place your hand on the cover and slide the cover down.
    • Use your hand to lift the cover from the bottom right and slide the cover to the right to remove the cover.
  4. HP Pavilion g6-2228tx Optical Drive Replacement: 步骤 4 中的图像 1,2 HP Pavilion g6-2228tx Optical Drive Replacement: 步骤 4 中的图像 2,2
    • Place one finger on the right side of the hard drive.
    • Push the hard drive to the left and lift the hard drive up to remove it from the device.
  5. HP Pavilion g6-2228tx Optical Drive Replacement: 步骤 5 中的图像 1,2 HP Pavilion g6-2228tx Optical Drive Replacement: 步骤 5 中的图像 2,2
    • Disconnect the connecting part by pulling the part to the right.
    • Remove the hard drive from the device.
  6. HP Pavilion g6-2228tx Optical Drive Replacement, Optical Drive: 步骤 6 中的图像 1,2 HP Pavilion g6-2228tx Optical Drive Replacement, Optical Drive: 步骤 6 中的图像 2,2
    • Remove the 2.5mm screw with a Phillips #0 screw drive.
  7. HP Pavilion g6-2228tx Optical Drive Replacement: 步骤 7 中的图像 1,3 HP Pavilion g6-2228tx Optical Drive Replacement: 步骤 7 中的图像 2,3 HP Pavilion g6-2228tx Optical Drive Replacement: 步骤 7 中的图像 3,3
    • Put one finger into the release hole and push to the left until part of the optical drive comes out from the left of the laptop.
  8. HP Pavilion g6-2228tx Optical Drive Replacement: 步骤 8 中的图像 1,3 HP Pavilion g6-2228tx Optical Drive Replacement: 步骤 8 中的图像 2,3 HP Pavilion g6-2228tx Optical Drive Replacement: 步骤 8 中的图像 3,3
    • Grab the optical drive and pull to the left to remove it from the device.
结论
Hai Lin
于10/19/18注册
446 声望
创作了4篇指南
团队
UC Davis, Team S4-G6, Lore Fall 2018 UC Davis, Team S4-G6, Lore Fall 2018 的会员
UCD-LORE-F18S4G6
3 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 17
总计 977
