跳转到主内容
HP Pavilion g6-1b79dx Wireless Card Replacement
你所需要的
  1. HP Pavilion g6-1b79dx Wireless Card Replacement, Battery: 步骤 1 中的图像 1,1
    • Flip the computer so the bottom is facing up with the battery away from you.
    • Turn off the computer and disconnect the charger.
  2. HP Pavilion g6-1b79dx Wireless Card Replacement: 步骤 2 中的图像 1,2 HP Pavilion g6-1b79dx Wireless Card Replacement: 步骤 2 中的图像 2,2
    • Slide the battery switch to the left until the battery unlatches from the base of the laptop.
  3. HP Pavilion g6-1b79dx Wireless Card Replacement: 步骤 3 中的图像 1,2 HP Pavilion g6-1b79dx Wireless Card Replacement: 步骤 3 中的图像 2,2
    • Lift the battery from its compartment away from the laptop.
  4. HP Pavilion g6-1b79dx Wireless Card Replacement, Bottom Panel: 步骤 4 中的图像 1,1
    • Loosen the two 5.7 mm screws on the bottom panel using a PH00 screwdriver.
    • The screws do not come out of the panel due to small washers. Do not try to remove the screws completely.
  5. HP Pavilion g6-1b79dx Wireless Card Replacement: 步骤 5 中的图像 1,1
    • Use the metal spudger all around the panel to pop it up from the base.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
    • Using your finger is acceptable but not entirely recommended. Be gentle if you choose to use your hands.
  6. HP Pavilion g6-1b79dx Wireless Card Replacement: 步骤 6 中的图像 1,3 HP Pavilion g6-1b79dx Wireless Card Replacement: 步骤 6 中的图像 2,3 HP Pavilion g6-1b79dx Wireless Card Replacement: 步骤 6 中的图像 3,3
    • With your hands, lift the panel completely off the base of the laptop.
  7. HP Pavilion g6-1b79dx Wireless Card Replacement, Wireless Card: 步骤 7 中的图像 1,3 HP Pavilion g6-1b79dx Wireless Card Replacement, Wireless Card: 步骤 7 中的图像 2,3 HP Pavilion g6-1b79dx Wireless Card Replacement, Wireless Card: 步骤 7 中的图像 3,3
    • Unlatch the two antenna cable connectors from the wireless card.
  8. HP Pavilion g6-1b79dx Wireless Card Replacement: 步骤 8 中的图像 1,1
    • Remove the two 2.5 mm screws in the wireless card with a PH00 screwdriver.
    • You may have to gently bend the cables away from the wireless card to remove the screws
  9. HP Pavilion g6-1b79dx Wireless Card Replacement: 步骤 9 中的图像 1,3 HP Pavilion g6-1b79dx Wireless Card Replacement: 步骤 9 中的图像 2,3 HP Pavilion g6-1b79dx Wireless Card Replacement: 步骤 9 中的图像 3,3
    • Gently disconnect the wireless card from the laptop.
结论
2等其他人完成本指南。
团队
Baylor, Team 10-12, Williams Fall 2015 Baylor, Team 10-12, Williams Fall 2015 的会员
BU-WILLIAMS-F15S10G12
3 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 17
总计 1,394
