跳转到主内容
简介
The motherboard is the meat of your device. Almost everything on the inside such as the fan, mouse pad, and speakers, are all attached. Although the removal and replacement of this component is not difficult, it should be done cautiously.
  1. HP Pavilion g4-1117dx Motherboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Slide pill shaped tab to the other side of the channel.
    • Remove battery while keeping the tab to the side.
  2. HP Pavilion g4-1117dx Motherboard Replacement, L-Shaped Back Panel: 步骤 3 中的图像 1,1
    • Unscrew the two screws JIS #0 located on opposites sides of the panel.
    • Screws are attached to the panel and will not fully come out.
  3. HP Pavilion g4-1117dx Motherboard Replacement: 步骤 4 中的图像 1,1
    • Carefully pry off the L-shaped panel.
  4. HP Pavilion g4-1117dx Motherboard Replacement, Hard Drive: 步骤 5 中的图像 1,1
    • Pull out and unplug the tab on the right hand side.
  5. HP Pavilion g4-1117dx Motherboard Replacement, Larger Back Panel: 步骤 6 中的图像 1,1
    • Unscrew all nine 6.0mm JIS #0 screws located on the border of the back panel.
  6. HP Pavilion g4-1117dx Motherboard Replacement: 步骤 7 中的图像 1,1
    • Remove 3 screws located where the battery previously was.
  7. HP Pavilion g4-1117dx Motherboard Replacement: 步骤 8 中的图像 1,2 HP Pavilion g4-1117dx Motherboard Replacement: 步骤 8 中的图像 2,2
    • Remove 6 screws located under the spot where the smaller L-shaped panel was located.
  8. HP Pavilion g4-1117dx Motherboard Replacement: 步骤 9 中的图像 1,1
    • Slowly pry off the keyboard from the back panel.
    • Between the back panel and the keyboard there are two ribbon wires.
    • Remove slowly to not break the back panel. If it does not come off easily, check to see if all screws are removed.
  9. HP Pavilion g4-1117dx Motherboard Replacement: 步骤 10 中的图像 1,1
    • Unplug wires connecting back panel to keyboard.
  10. HP Pavilion g4-1117dx Motherboard Replacement, Motherboard: 步骤 11 中的图像 1,2 HP Pavilion g4-1117dx Motherboard Replacement, Motherboard: 步骤 11 中的图像 2,2
    • In lower left hand corner, pull on black tab to unplug the disc drive.
  11. HP Pavilion g4-1117dx Motherboard Replacement: 步骤 12 中的图像 1,2 HP Pavilion g4-1117dx Motherboard Replacement: 步骤 12 中的图像 2,2
    • In upper left hand corner, unplug the large black electrical tape covered laptop plug.
结论
Robert Hamilton
于2018年03月01日注册
1,072 声望分
创作了10篇指南
团队
UMass Dartmouth, Team S2-G7, Simcock Spring 2018 UMass Dartmouth, Team S2-G7, Simcock Spring 2018 的会员
UMASSD-SIMCOCK-S18S2G7
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去的24小时: 1
过去的7天: 4
过去的30天: 22
总计 875
