当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Slide pill shaped tab to the other side of the channel.
Remove battery while keeping the tab to the side.
Unscrew the two screws JIS #0 located on opposites sides of the panel.
Screws are attached to the panel and will not fully come out.
Carefully pry off the L-shaped panel.
Unscrew all nine 6.0mm JIS #0 screws located on the border of the back panel.
Remove 3 screws located where the battery previously was.
Remove 6 screws located under the spot where the smaller L-shaped panel was located.
Slowly pry off the keyboard from the back panel.
Between the back panel and the keyboard there are two ribbon wires.
Remove slowly to not break the back panel. If it does not come off easily, check to see if all screws are removed.
Unplug wires connecting back panel to keyboard.
取消:我没有完成这个指南。
与1其他贡献者
于03/01/18注册
1,165 声望
创作了10篇指南
徽章: 10
+ 7更多徽章
UMASSD-SIMCOCK-S18S2G7
4 名成员
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 3
过去 7 天: 6
过去 30 天: 9
总计 390
