跳转到主内容
HP Pavilion g4-1117dx Larger Back Panel Replacement
你所需要的
  1. HP Pavilion g4-1117dx Larger Back Panel Replacement, Battery: 步骤 1 中的图像 1,1
    • Slide pill shaped tab to the other side of the channel.
    • Remove battery while keeping the tab to the side.
  2. HP Pavilion g4-1117dx Larger Back Panel Replacement, L-Shaped Back Panel: 步骤 3 中的图像 1,1
    • Unscrew the two screws JIS #0 located on opposites sides of the panel.
    • Screws are attached to the panel and will not fully come out.
  3. HP Pavilion g4-1117dx Larger Back Panel Replacement: 步骤 4 中的图像 1,1
    • Carefully pry off the L-shaped panel.
  4. HP Pavilion g4-1117dx Larger Back Panel Replacement, Larger Back Panel: 步骤 5 中的图像 1,1
    • Unscrew all nine 6.0mm JIS #0 screws located on the border of the back panel.
  5. HP Pavilion g4-1117dx Larger Back Panel Replacement: 步骤 6 中的图像 1,1
    • Remove 3 screws located where the battery previously was.
  6. HP Pavilion g4-1117dx Larger Back Panel Replacement: 步骤 7 中的图像 1,2 HP Pavilion g4-1117dx Larger Back Panel Replacement: 步骤 7 中的图像 2,2
    • Remove 6 screws located under the spot where the smaller L-shaped panel was located.
  7. HP Pavilion g4-1117dx Larger Back Panel Replacement: 步骤 8 中的图像 1,1
    • Slowly pry off the keyboard from the back panel.
    • Between the back panel and the keyboard there are two ribbon wires.
    • Remove slowly to not break the back panel. If it does not come off easily, check to see if all screws are removed.
  8. HP Pavilion g4-1117dx Larger Back Panel Replacement: 步骤 9 中的图像 1,1
    • Unplug wires connecting back panel to keyboard.
结论
Robert Hamilton
于03/01/18注册
1,165 声望
创作了10篇指南
团队
UMass Dartmouth, Team S2-G7, Simcock Spring 2018 UMass Dartmouth, Team S2-G7, Simcock Spring 2018 的会员
UMASSD-SIMCOCK-S18S2G7
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 14
总计 413
