当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Slowly pry off the keyboard from the back panel.
Between the back panel and the keyboard there are two ribbon wires.
Remove slowly to not break the back panel. If it does not come off easily, check to see if all screws are removed.
Unscrew the four screws JIS #0 screws on the back side of the motherboard.
Screws will loosen but do not come completely out.
The screws are the only thing keeping the fan attached to the motherboard.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
