跳转到主内容
HP Pavilion g4-1117dx Fan Replacement
你所需要的
  1. HP Pavilion g4-1117dx Fan Replacement, Battery: 步骤 1 中的图像 1,1
    • Slide pill shaped tab to the other side of the channel.
    • Remove battery while keeping the tab to the side.
  2. HP Pavilion g4-1117dx Fan Replacement, L-Shaped Back Panel: 步骤 3 中的图像 1,1
    • Unscrew the two screws JIS #0 located on opposites sides of the panel.
    • Screws are attached to the panel and will not fully come out.
  3. HP Pavilion g4-1117dx Fan Replacement: 步骤 4 中的图像 1,1
    • Carefully pry off the L-shaped panel.
  4. HP Pavilion g4-1117dx Fan Replacement, Hard Drive: 步骤 5 中的图像 1,1
    • Pull out and unplug the tab on the right hand side.
  5. HP Pavilion g4-1117dx Fan Replacement, Larger Back Panel: 步骤 6 中的图像 1,1
    • Unscrew all nine 6.0mm JIS #0 screws located on the border of the back panel.
  6. HP Pavilion g4-1117dx Fan Replacement: 步骤 7 中的图像 1,1
    • Remove 3 screws located where the battery previously was.
  7. HP Pavilion g4-1117dx Fan Replacement: 步骤 8 中的图像 1,2 HP Pavilion g4-1117dx Fan Replacement: 步骤 8 中的图像 2,2
    • Remove 6 screws located under the spot where the smaller L-shaped panel was located.
  8. HP Pavilion g4-1117dx Fan Replacement: 步骤 9 中的图像 1,1
    • Slowly pry off the keyboard from the back panel.
    • Between the back panel and the keyboard there are two ribbon wires.
    • Remove slowly to not break the back panel. If it does not come off easily, check to see if all screws are removed.
  9. HP Pavilion g4-1117dx Fan Replacement: 步骤 10 中的图像 1,1
    • Unplug wires connecting back panel to keyboard.
  10. HP Pavilion g4-1117dx Fan Replacement, Motherboard: 步骤 11 中的图像 1,2 HP Pavilion g4-1117dx Fan Replacement, Motherboard: 步骤 11 中的图像 2,2
    • In lower left hand corner, pull on black tab to unplug the disc drive.
  11. HP Pavilion g4-1117dx Fan Replacement: 步骤 12 中的图像 1,2 HP Pavilion g4-1117dx Fan Replacement: 步骤 12 中的图像 2,2
    • In upper left hand corner, unplug the large black electrical tape covered laptop plug.
  12. HP Pavilion g4-1117dx Fan Replacement, Fan: 步骤 13 中的图像 1,2 HP Pavilion g4-1117dx Fan Replacement, Fan: 步骤 13 中的图像 2,2
    • Unscrew the four screws JIS #0 screws on the back side of the motherboard.
    • Screws will loosen but do not come completely out.
    • The screws are the only thing keeping the fan attached to the motherboard.
结论
Robert Hamilton
于03/01/18注册
1,165 声望
创作了10篇指南
团队
UMass Dartmouth, Team S2-G7, Simcock Spring 2018 UMass Dartmouth, Team S2-G7, Simcock Spring 2018 的会员
UMASSD-SIMCOCK-S18S2G7
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 19
总计 1,942
