当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Turn the laptop over to expose the bottom side.
Locate the battery removal switch next to the battery compartment
Important: Before doing any repairs on the laptop, make sure it is completely powered down and unplugged.
Locate the panel that lies in the front center of the laptops underside.
Using a Phillips #1 screwdriver, remove the two 5mm screws on the forward end of the cover.
Lift off the cover to expose the Wi-Fi card underneath.
Locate the Wi-Fi card inside of the computer.
With a Phillips #1 screwdriver, remove the two 11mm screws on either side of the wires attached to the top of the Wi-Fi card.
Lift the card from its resting location. Be careful, the card and attached wires are fragile.
Carefully pop the wires off of the Wi-Fi card. They should easily come off with a light tug.
As you take each wire off, keep track of the numbered labels. These numbers correspond with contact points on the card.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
