跳转到主内容
HP Pavilion dv9000 Wireless Card Replacement
你所需要的
  1. HP Pavilion dv9000 Wireless Card Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn the laptop over to expose the bottom side.
    • Locate the battery removal switch next to the battery compartment
    • Important: Before doing any repairs on the laptop, make sure it is completely powered down and unplugged.
  2. HP Pavilion dv9000 Wireless Card Replacement, Battery Removal: 步骤 2 中的图像 1,2 HP Pavilion dv9000 Wireless Card Replacement, Battery Removal: 步骤 2 中的图像 2,2
    • Slide the switch all the way to the left to release the battery. The battery should pop up.
    • Lift the battery out.
  3. HP Pavilion dv9000 Wireless Card Replacement, Wireless Card: 步骤 3 中的图像 1,3 HP Pavilion dv9000 Wireless Card Replacement, Wireless Card: 步骤 3 中的图像 2,3 HP Pavilion dv9000 Wireless Card Replacement, Wireless Card: 步骤 3 中的图像 3,3
    • Locate the panel that lies in the front center of the laptops underside.
    • Using a Phillips #1 screwdriver, remove the two 5mm screws on the forward end of the cover.
    • Lift off the cover to expose the Wi-Fi card underneath.
  4. HP Pavilion dv9000 Wireless Card Replacement: 步骤 4 中的图像 1,3 HP Pavilion dv9000 Wireless Card Replacement: 步骤 4 中的图像 2,3 HP Pavilion dv9000 Wireless Card Replacement: 步骤 4 中的图像 3,3
    • Locate the Wi-Fi card inside of the computer.
    • With a Phillips #1 screwdriver, remove the two 11mm screws on either side of the wires attached to the top of the Wi-Fi card.
    • Lift the card from its resting location. Be careful, the card and attached wires are fragile.
  5. HP Pavilion dv9000 Wireless Card Replacement: 步骤 5 中的图像 1,2 HP Pavilion dv9000 Wireless Card Replacement: 步骤 5 中的图像 2,2
    • Carefully pop the wires off of the Wi-Fi card. They should easily come off with a light tug.
    • As you take each wire off, keep track of the numbered labels. These numbers correspond with contact points on the card.
结论
2等其他人完成本指南。
Erik Hoffnagle
于04/11/13注册
771 声望
创作了3篇指南
团队
Cal Poly, Team 10-32, Maness Winter 2014 Cal Poly, Team 10-32, Maness Winter 2014 的会员
CPSU-MANESS-W14S10G32
4 名成员
创作了6篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 9
总计 4,046
