跳转到主内容
HP Pavilion dv9000 RAM Replacement
你所需要的
  1. HP Pavilion dv9000 RAM Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn the laptop over to expose the bottom side.
    • Locate the battery removal switch next to the battery compartment
    • Important: Before doing any repairs on the laptop, make sure it is completely powered down and unplugged.
  2. HP Pavilion dv9000 RAM Replacement, Battery Removal: 步骤 2 中的图像 1,2 HP Pavilion dv9000 RAM Replacement, Battery Removal: 步骤 2 中的图像 2,2
    • Slide the switch all the way to the left to release the battery. The battery should pop up.
    • Lift the battery out.
  3. HP Pavilion dv9000 RAM Replacement, RAM: 步骤 3 中的图像 1,3 HP Pavilion dv9000 RAM Replacement, RAM: 步骤 3 中的图像 2,3 HP Pavilion dv9000 RAM Replacement, RAM: 步骤 3 中的图像 3,3
    • Locate the middle plastic cover on the bottom of the laptop.
    • Unscrew the two 5mm screws using a Phillips #1 screwdriver. The screws should remain in the plastic cover.
    • Lift and remove the plastic cover.
  4. HP Pavilion dv9000 RAM Replacement: 步骤 4 中的图像 1,3 HP Pavilion dv9000 RAM Replacement: 步骤 4 中的图像 2,3 HP Pavilion dv9000 RAM Replacement: 步骤 4 中的图像 3,3
    • Locate the RAM card and the metal tabs on either side of it.
    • Press both tabs away from the RAM card to release it. The card should flip up towards you.
    • Carefully lift the RAM card out.
结论
另外一个人完成了本指南。
Erik Hoffnagle
于04/11/13注册
768 声望
创作了3篇指南
团队
Cal Poly, Team 10-32, Maness Winter 2014 Cal Poly, Team 10-32, Maness Winter 2014 的会员
CPSU-MANESS-W14S10G32
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 12
总计 3,552
