跳转到主内容
HP Pavilion dv7t-7000 Speaker Replacement
你所需要的
  1. HP Pavilion dv7t-7000 Speaker Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn the computer off and disconnect if from all power sources.
  2. HP Pavilion dv7t-7000 Speaker Replacement: 步骤 2 中的图像 1,1
    • Slide the battery release switch to the left.
  3. HP Pavilion dv7t-7000 Speaker Replacement: 步骤 3 中的图像 1,1
    • Hold the release switch all of the way to the left and your other hand to pull the battery out.
  4. HP Pavilion dv7t-7000 Speaker Replacement, Back Panel: 步骤 4 中的图像 1,1
    • Unscrew the single Phillips #00 screw.
    • Screw will not come out, it is connected to the panel
  5. HP Pavilion dv7t-7000 Speaker Replacement: 步骤 5 中的图像 1,2 HP Pavilion dv7t-7000 Speaker Replacement: 步骤 5 中的图像 2,2
    • Remove service hatch by sliding away from the computer and lifting up.
  6. HP Pavilion dv7t-7000 Speaker Replacement, Keyboard: 步骤 6 中的图像 1,2 HP Pavilion dv7t-7000 Speaker Replacement, Keyboard: 步骤 6 中的图像 2,2
    • Remove the single Phillips #00 screw.
    • Flip the laptop over.
  7. HP Pavilion dv7t-7000 Speaker Replacement: 步骤 7 中的图像 1,3 HP Pavilion dv7t-7000 Speaker Replacement: 步骤 7 中的图像 2,3 HP Pavilion dv7t-7000 Speaker Replacement: 步骤 7 中的图像 3,3
    • Wedge a spudger in between the keyboard and the upper bezel (nearest the screen).
    • Pry upward to release the keyboard clips.
    • The keyboard is plugged into the motherboard, so be careful not to pull out while lifting keyboard.
  8. HP Pavilion dv7t-7000 Speaker Replacement: 步骤 8 中的图像 1,1
    • Use the flat end of a spudger to flip up the black tab on the ZIF connectors.
    • Pull the ribbon cables out of the ZIF connectors.
    • Remove the keyboard.
  9. HP Pavilion dv7t-7000 Speaker Replacement, Speaker: 步骤 9 中的图像 1,3 HP Pavilion dv7t-7000 Speaker Replacement, Speaker: 步骤 9 中的图像 2,3 HP Pavilion dv7t-7000 Speaker Replacement, Speaker: 步骤 9 中的图像 3,3
    • Use Phillips #00 to unscrew the screw and take off the front panel.
  10. HP Pavilion dv7t-7000 Speaker Replacement: 步骤 10 中的图像 1,2 HP Pavilion dv7t-7000 Speaker Replacement: 步骤 10 中的图像 2,2
    • The speaker is located at the back side of the front panel.
    • Unscrew two screws located at the speaker.
  11. HP Pavilion dv7t-7000 Speaker Replacement: 步骤 11 中的图像 1,1
    • Pull out the speakers to remove.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 13
总计 1,328
