跳转到主内容
HP Pavilion dv7t-7000 Hard Drive Replacement
你所需要的
  1. HP Pavilion dv7t-7000 Hard Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn the computer off and disconnect if from all power sources.
  2. HP Pavilion dv7t-7000 Hard Drive Replacement: 步骤 2 中的图像 1,1
    • Slide the battery release switch to the left.
  3. HP Pavilion dv7t-7000 Hard Drive Replacement: 步骤 3 中的图像 1,1
    • Hold the release switch all of the way to the left and your other hand to pull the battery out.
  4. HP Pavilion dv7t-7000 Hard Drive Replacement, Back Panel: 步骤 4 中的图像 1,1
    • Unscrew the single Phillips #00 screw.
    • Screw will not come out, it is connected to the panel
  5. HP Pavilion dv7t-7000 Hard Drive Replacement: 步骤 5 中的图像 1,2 HP Pavilion dv7t-7000 Hard Drive Replacement: 步骤 5 中的图像 2,2
    • Remove service hatch by sliding away from the computer and lifting up.
  6. HP Pavilion dv7t-7000 Hard Drive Replacement, Hard Drive: 步骤 6 中的图像 1,1
    • Remove the two Phillips #00 screws holding in the hard drive.
  7. HP Pavilion dv7t-7000 Hard Drive Replacement: 步骤 7 中的图像 1,2 HP Pavilion dv7t-7000 Hard Drive Replacement: 步骤 7 中的图像 2,2
    • Grab the black tab on the hard drive and pull left and then upwards to remove.
  8. HP Pavilion dv7t-7000 Hard Drive Replacement: 步骤 8 中的图像 1,1
    • Remove the four Phillips #00 screws holding the hard drive to its case.
  9. HP Pavilion dv7t-7000 Hard Drive Replacement: 步骤 9 中的图像 1,2 HP Pavilion dv7t-7000 Hard Drive Replacement: 步骤 9 中的图像 2,2
    • Slide the casing off of the hard drive.
  10. HP Pavilion dv7t-7000 Hard Drive Replacement: 步骤 10 中的图像 1,1
    • Unplug the hard drive from the device.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 10
总计 404
