跳转到主内容
HP Pavilion dv7-6178us RAM Replacement
  1. HP Pavilion dv7-6178us RAM Replacement, RAM: 步骤 1 中的图像 1,2 HP Pavilion dv7-6178us RAM Replacement, RAM: 步骤 1 中的图像 2,2
    • Flip over the laptop and push the sliding lock to the right (or whichever side indicates it with a symbol.)
    • After that is done, carefully pull off the back piece. It should look similar to the second photo.
  2. HP Pavilion dv7-6178us RAM Replacement: 步骤 2 中的图像 1,1
    • Locate the RAM and push the two tabs on the sides away from the RAM.
  3. HP Pavilion dv7-6178us RAM Replacement: 步骤 3 中的图像 1,1
    • Once the tabs on the sides are released the RAM card will pop out by itself to this angle, as shown in the picture.
  4. HP Pavilion dv7-6178us RAM Replacement: 步骤 4 中的图像 1,1
    • Pull the card out of the socket and you have successfully removed one RAM card.
  5. HP Pavilion dv7-6178us RAM Replacement: 步骤 5 中的图像 1,2 HP Pavilion dv7-6178us RAM Replacement: 步骤 5 中的图像 2,2
    • Steps 2 through 4 can also be done on the second RAM card, located directly below the initial RAM card.
结论
Branden Simas
于10/20/18注册
178 声望
撰写一个指南
团队
UMass Dartmouth, Team S4-G8, Valliere Fall 2018 UMass Dartmouth, Team S4-G8, Valliere Fall 2018 的会员
UMASSD-VALLIERE-F18S4G8
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 10
总计 656
