跳转到主内容
HP Pavilion dv7-6178us Hard Drive Replacement
你所需要的
  1. HP Pavilion dv7-6178us Hard Drive Replacement, Hard Drive: 步骤 1 中的图像 1,2 HP Pavilion dv7-6178us Hard Drive Replacement, Hard Drive: 步骤 1 中的图像 2,2
    • Flip over the laptop and push the sliding lock to the right (or whichever side indicates it with a symbol.)
    • After that is done, carefully pull off the back piece. It should look similar to the second photo.
  2. HP Pavilion dv7-6178us Hard Drive Replacement: 步骤 2 中的图像 1,1
    • Now, with the back piece off, you will remove the four screws holding it in place. Use a Phillips head screwdriver.
    • Take note of where you place the screws because you will need them for later.
  3. HP Pavilion dv7-6178us Hard Drive Replacement: 步骤 3 中的图像 1,2 HP Pavilion dv7-6178us Hard Drive Replacement: 步骤 3 中的图像 2,2
    • Place the old hard drive off to the side (as seen in photo) and carefully remove the SATA cable from laptop.
    • Be careful to not damage the laptop or cable when doing this step. A gentle pull should do the trick.
结论
2等其他人完成本指南。
Zach Lunghi
于10/19/18注册
148 声望
撰写一个指南
团队
UMass Dartmouth, Team S4-G8, Valliere Fall 2018 UMass Dartmouth, Team S4-G8, Valliere Fall 2018 的会员
UMASSD-VALLIERE-F18S4G8
4 名成员
创作了6篇指南
1指南评论
This is a really GREAT thing that's being done!
It's high time that consumers fought back and stop letting the TECHNO-OVERLORDS, collectively STRIP us of the right to use the digital tools that we purchase from them.
Walter D Wormack - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 21
总计 2,163
