跳转到主内容
HP Pavilion dv7-3065dx Hard Drive Replacement
你所需要的
  1. HP Pavilion dv7-3065dx Hard Drive Replacement, Battery: 步骤 1 中的图像 1,2 HP Pavilion dv7-3065dx Hard Drive Replacement, Battery: 步骤 1 中的图像 2,2
    • Turn off the device before removing the battery.
    • Place the laptop upside down on a flat surface so that the bottom is facing up.
    • The battery is the long rectangle above the latch.
  2. HP Pavilion dv7-3065dx Hard Drive Replacement: 步骤 2 中的图像 1,1
    • Slide the battery latch to the left to release the battery.
  3. HP Pavilion dv7-3065dx Hard Drive Replacement: 步骤 3 中的图像 1,2 HP Pavilion dv7-3065dx Hard Drive Replacement: 步骤 3 中的图像 2,2
    • Carefully pull out the battery while holding the latch to the open position with your finger.
  4. HP Pavilion dv7-3065dx Hard Drive Replacement, Hard Drive: 步骤 4 中的图像 1,1
    • Loosen the four screws that secure the hard drive panel with a Phillips head screwdriver.
    • Do not completely remove the screws from the panel.
  5. HP Pavilion dv7-3065dx Hard Drive Replacement: 步骤 5 中的图像 1,1
    • Lift the drive cover to expose the hard drive.
    • This device did not have a physical hard drive to work with.
    • Gently tug on the black tabs located on each end of the hard drive in order to loosen the hard drive from the motherboard.
    • Be careful when working with the hard drive cable.
    • Separate the hard drive from the cable by firmly gripping the hard drive and the black plug.
    • Remove the four Phillips screws that secure the hard drive to its carrier.
    • There are two screws on each side.
    • Lift and remove the hard drive from the metal surrounding its perimeter.
结论
2等其他人完成本指南。
Gabi Marino
于02/07/17注册
157 声望
撰写一个指南
团队
Ohio State, Team 1-5, Wilder Spring 2017 Ohio State, Team 1-5, Wilder Spring 2017 的会员
OSU-WILDER-S17S1G5
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 17
总计 3,526
