跳转到主内容
HP Pavilion dv7-1448dx RAM Replacement
你所需要的
  1. HP Pavilion dv7-1448dx RAM Replacement, Battery: 步骤 1 中的图像 1,1
    • Make sure the computer is unplugged and turned off.
    • Place the computer front side down with the battery compartment farthest away.
  2. HP Pavilion dv7-1448dx RAM Replacement: 步骤 2 中的图像 1,2 HP Pavilion dv7-1448dx RAM Replacement: 步骤 2 中的图像 2,2
    • Slide the switch under the battery compartment to the left until the compartment opens. This may require some force.
  3. HP Pavilion dv7-1448dx RAM Replacement: 步骤 3 中的图像 1,2 HP Pavilion dv7-1448dx RAM Replacement: 步骤 3 中的图像 2,2
    • Lightly pry the battery upward to remove.
    • When reinserting the battery, match the latches along the backside of the battery with the corresponding slots in the computer in order to press it into place.
  4. HP Pavilion dv7-1448dx RAM Replacement, RAM: 步骤 4 中的图像 1,3 HP Pavilion dv7-1448dx RAM Replacement, RAM: 步骤 4 中的图像 2,3 HP Pavilion dv7-1448dx RAM Replacement, RAM: 步骤 4 中的图像 3,3
    • Remove the six Phillips PM2.5X6.0 screws with a Phillips #00 screwdriver.
    • Pry the back casing up and away from the rest of the laptop with the plastic opening tool.
  5. HP Pavilion dv7-1448dx RAM Replacement: 步骤 5 中的图像 1,3 HP Pavilion dv7-1448dx RAM Replacement: 步骤 5 中的图像 2,3 HP Pavilion dv7-1448dx RAM Replacement: 步骤 5 中的图像 3,3
    • Remove the green RAM by prying it upward and pulling it away from its slot.
结论
团队
Baylor, Team 3-5, Whitney Spring 2017 Baylor, Team 3-5, Whitney Spring 2017 的会员
BU-WHITNEY-S17S3G5
2 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 11
总计 334
