跳转到主内容
HP Pavilion dv7-1448dx Key Replacement
你所需要的
  1. HP Pavilion dv7-1448dx Key Replacement, Key: 步骤 1 中的图像 1,1
    • Make sure the computer is unplugged and turned off.
    • Open the laptop so that the keyboard is fully exposed.
  2. HP Pavilion dv7-1448dx Key Replacement: 步骤 2 中的图像 1,1
    • Place the plastic opening tool in the crevice near the key that needs to be removed.
    • This works best if the tool is placed at the top of the key.
  3. HP Pavilion dv7-1448dx Key Replacement: 步骤 3 中的图像 1,1
    • Gently lever the tool downward until the key tilts upward.
    • At this point, move the tool around in order to completely pry the key off the keyboard. As the key is removed, small pops will be heard.
    • This step may take longer for larger keys.
    • When reinserting the key, gently press down until 2 clicks are heard (4 for larger keys).
  4. HP Pavilion dv7-1448dx Key Replacement: 步骤 4 中的图像 1,1
    • Carefully remove the key from the base.
  5. HP Pavilion dv7-1448dx Key Replacement: 步骤 5 中的图像 1,1
    • If the issue is a sticky key, make sure to clean the area once it is removed.
    • Use a cotton swab with alcohol to clean the underside of the key and the key slot.
结论
团队
Baylor, Team 3-5, Whitney Spring 2017 Baylor, Team 3-5, Whitney Spring 2017 的会员
BU-WHITNEY-S17S3G5
2 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 11
总计 368
