跳转到主内容
HP Pavilion dv7-1285dx Wifi Card Replacement
你所需要的
  1. HP Pavilion dv7-1285dx Wifi Card Replacement, Battery: 步骤 1 中的图像 1,1
    • Ensure the device is powered down and unplugged.
    • Turn the device upside down with the battery compartment facing you.
    • Slide the black slider to the right and lift the battery out of its compartment.
  2. HP Pavilion dv7-1285dx Wifi Card Replacement, Back Plate: 步骤 2 中的图像 1,1
    • Locate and remove the six Phillips PM2.5×7.0 screws around the perimeter of the back plate.
    • These screws do not completely detach from the device when unscrewed.
  3. HP Pavilion dv7-1285dx Wifi Card Replacement: 步骤 3 中的图像 1,2 HP Pavilion dv7-1285dx Wifi Card Replacement: 步骤 3 中的图像 2,2
    • Use the plastic opening tool to lift up the back plate and set it aside.
  4. HP Pavilion dv7-1285dx Wifi Card Replacement, Wifi Card: 步骤 4 中的图像 1,1
    • Locate the wifi card to the right of the RAM.
  5. HP Pavilion dv7-1285dx Wifi Card Replacement: 步骤 5 中的图像 1,1
    • Unplug antenna cables 1 and 2 from their leads.
    • Antenna cable 3 is not used.
  6. HP Pavilion dv7-1285dx Wifi Card Replacement: 步骤 6 中的图像 1,1
    • Remove the two Phillips head screws located on the battery compartment side of the wifi card.
  7. HP Pavilion dv7-1285dx Wifi Card Replacement: 步骤 7 中的图像 1,1
    • Gently lift the wifi card up to a 45 degree angle from the side with screws.
  8. HP Pavilion dv7-1285dx Wifi Card Replacement: 步骤 8 中的图像 1,2 HP Pavilion dv7-1285dx Wifi Card Replacement: 步骤 8 中的图像 2,2
    • Unplug the wifi card.
  9. HP Pavilion dv7-1285dx Wifi Card Replacement: 步骤 9 中的图像 1,1
    • These next steps are for installing your replacement wifi card. These steps are very important to ensure that you do not damage your device.
    • Fully insert the replacement wifi card at a 45 degree angle, ensuring that the notch on the card lines up with the peg on the plug.
  10. HP Pavilion dv7-1285dx Wifi Card Replacement: 步骤 10 中的图像 1,1
    • Gently push the wifi card down until the screws can be replaced.
  11. HP Pavilion dv7-1285dx Wifi Card Replacement: 步骤 11 中的图像 1,1
    • Connect the antenna cable 1 with lead 1 and connect antenna cable 2 with lead 2.
    • Wire 1 needs to be connected to lead 1 and wire 2 needs to be connected to lead 2.
    • Wire 3 and lead 3 are not used.
结论
2等其他人完成本指南。
Anmol Mathur
于04/14/14注册
291 声望
创作了2篇指南
团队
Cal Poly, Team 12-34, Maness Spring 2014 Cal Poly, Team 12-34, Maness Spring 2014 的会员
CPSU-MANESS-S14S12G34
4 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 4
过去 30 天: 18
总计 2,158
