跳转到主内容
HP Pavilion dv7-1285dx Keyboard Replacement
你所需要的
  1. HP Pavilion dv7-1285dx Keyboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Ensure the device is powered down and unplugged.
    • Turn the device upside down with the battery compartment facing you.
    • Slide the black slider to the right and lift the battery out of its compartment.
  2. HP Pavilion dv7-1285dx Keyboard Replacement, Keyboard: 步骤 2 中的图像 1,2 HP Pavilion dv7-1285dx Keyboard Replacement, Keyboard: 步骤 2 中的图像 2,2
    • Using a Phillips Screwdriver, remove the four Phillips M25x3.0 head screws.
  3. HP Pavilion dv7-1285dx Keyboard Replacement: 步骤 3 中的图像 1,2 HP Pavilion dv7-1285dx Keyboard Replacement: 步骤 3 中的图像 2,2
    • Using a plastic opening tool on both the left and right sides to remove the upper portion of the top plate.
    • Orient the device such that it’s partially opened (a little less than a 45 degree angle) and the hinge faces up.
  4. HP Pavilion dv7-1285dx Keyboard Replacement: 步骤 4 中的图像 1,2 HP Pavilion dv7-1285dx Keyboard Replacement: 步骤 4 中的图像 2,2
    • Orient the laptop so the screen is open and facing you.
    • Grasp the top plate near the hinge and pull up.
    • This should expose a white ribbon cable.
  5. HP Pavilion dv7-1285dx Keyboard Replacement: 步骤 5 中的图像 1,2 HP Pavilion dv7-1285dx Keyboard Replacement: 步骤 5 中的图像 2,2
    • Locate the dark grey slide on the sides of the ribbon cable plug.
    • Using the plastic opening tool, push both sides of the dark gray slide towards the screen of the computer.
    • Unplug the ribbon cable and set the top plate aside.
  6. HP Pavilion dv7-1285dx Keyboard Replacement: 步骤 6 中的图像 1,2 HP Pavilion dv7-1285dx Keyboard Replacement: 步骤 6 中的图像 2,2
    • Locate the four Phillips M2.0x2 head screws at the top of the keyboard and remove them.
    • Gently lift the keyboard up from the screen side and pull the keyboard towards the screen.
  7. HP Pavilion dv7-1285dx Keyboard Replacement: 步骤 7 中的图像 1,3 HP Pavilion dv7-1285dx Keyboard Replacement: 步骤 7 中的图像 2,3 HP Pavilion dv7-1285dx Keyboard Replacement: 步骤 7 中的图像 3,3
    • Locate the black ribbon cable attaching the keyboard to the computer.
    • Find the grey slides on the side of the ribbon cable plug.
    • Use the plastic opening tool to move the grey slides toward the screen.
    • Unplug the black ribbon cable.
    • Remove the keyboard.
结论
2等其他人完成本指南。
Jesse Quisido
于04/14/14注册
489 声望
创作了3篇指南
团队
Cal Poly, Team 12-34, Maness Spring 2014 Cal Poly, Team 12-34, Maness Spring 2014 的会员
CPSU-MANESS-S14S12G34
4 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 17
总计 3,832
