跳转到主内容
HP Pavilion dv7-1285dx Back Plate Replacement
你所需要的
  1. HP Pavilion dv7-1285dx Back Plate Replacement, Battery: 步骤 1 中的图像 1,1
    • Ensure the device is powered down and unplugged.
    • Turn the device upside down with the battery compartment facing you.
    • Slide the black slider to the right and lift the battery out of its compartment.
  2. HP Pavilion dv7-1285dx Back Plate Replacement, Back Plate: 步骤 2 中的图像 1,1
    • Locate and remove the six Phillips PM2.5×7.0 screws around the perimeter of the back plate.
    • These screws do not completely detach from the device when unscrewed.
  3. HP Pavilion dv7-1285dx Back Plate Replacement: 步骤 3 中的图像 1,2 HP Pavilion dv7-1285dx Back Plate Replacement: 步骤 3 中的图像 2,2
    • Use the plastic opening tool to lift up the back plate and set it aside.
结论
Chris Apple
于04/14/14注册
239 声望
创作了2篇指南
团队
Cal Poly, Team 12-34, Maness Spring 2014 Cal Poly, Team 12-34, Maness Spring 2014 的会员
CPSU-MANESS-S14S12G34
4 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 13
总计 1,526
