跳转到主内容
HP Pavilion dv6500 Speaker Replacement
你所需要的
  1. HP Pavilion dv6500 Speaker Replacement, Speaker: 步骤 1 中的图像 1,1
    • Remove all 4 of the 7.0mm screws and the 3 silver, smaller 4.0mm screws inside the cavity of the battery
  2. HP Pavilion dv6500 Speaker Replacement: 步骤 2 中的图像 1,2 HP Pavilion dv6500 Speaker Replacement: 步骤 2 中的图像 2,2
    • Gently lift the plastic panel on the top of the laptop at the divide until the two ribbon cables and cable leads are visible with their ports on left side on laptop.
  3. HP Pavilion dv6500 Speaker Replacement: 步骤 3 中的图像 1,1
    • Gently pull on the 2 ribbon cables until they detach from the computer.
    • Unplug cables connecting the top keyboard assembly and computer body.
    • Be careful not to rip the speaker cables.
结论
Andrew
于10/23/16注册
392 声望
创作了3篇指南
团队
UMass Dartmouth, Team 1-6, Catania Fall 2016 UMass Dartmouth, Team 1-6, Catania Fall 2016 的会员
UMASSD-CATANIA-F16S1G6
3 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 11
总计 749
