跳转到主内容
HP Pavilion dv6500 Keyboard Replacement
你所需要的
  1. HP Pavilion dv6500 Keyboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Flip computer face down.
  2. HP Pavilion dv6500 Keyboard Replacement: 步骤 2 中的图像 1,1
    • Remove the battery by sliding the button to the side.
    • Be careful if the battery is leaking or appears punctured in anyway. Battery acid is harmful and may cause burns.
  3. HP Pavilion dv6500 Keyboard Replacement, Back Panel: 步骤 3 中的图像 1,1
    • Remove fifteen 7.0mm PH0 screws.
    • Remove five silver 4.0mm PH 0 screws inside the cavity for the battery.
  4. HP Pavilion dv6500 Keyboard Replacement, Keyboard: 步骤 4 中的图像 1,2 HP Pavilion dv6500 Keyboard Replacement, Keyboard: 步骤 4 中的图像 2,2
    • Gently lift the plastic panel on the top of the laptop at the divide until the two ribbon cables and cable leads are visible with their ports on left side on laptop.
  5. HP Pavilion dv6500 Keyboard Replacement: 步骤 5 中的图像 1,1
    • Gently pull on the 2 ribbon cables until they detach from the computer.
    • Unplug cables connecting the top keyboard assembly and computer body.
    • Be careful not to rip the speaker cables.
  6. HP Pavilion dv6500 Keyboard Replacement: 步骤 6 中的图像 1,1
    • The top of the keyboard should be exposed enough to unclip and slide the keyboard out from the clips near the trackpad on the laptop.
    • Gently pull the flat black cable toward the monitor to remove the cable from the motherboard, freeing the keyboard.
    • Be careful not to pull too hard and damage the black cable.
  7. HP Pavilion dv6500 Keyboard Replacement: 步骤 7 中的图像 1,1
    • Insert new keyboard by sliding it into place of original keyboard and clipping into place near top of trackpad.
结论
另外一个人完成了本指南。
ollie
于10/20/16注册
575 声望
创作了4篇指南
团队
UMass Dartmouth, Team 1-6, Catania Fall 2016 UMass Dartmouth, Team 1-6, Catania Fall 2016 的会员
UMASSD-CATANIA-F16S1G6
3 名成员
创作了7篇指南
一条评论
Je constate que régulièrement, il n’est pas mentionné de se décharger de son électricité statique. En dehors de tout équimement spécifique, il suffit, par exemple de toucher le bouton de purge d’un radiateur de chauffage central ou la fiche “terre” d’une prise 2 + T
Bernard RUETTE - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 5
总计 1,613
