跳转到主内容
简介
Replace the wireless card in your HP Pavilion dv6000.
  1. Lay the laptop on a flat surface, battery side up.
    • Lay the laptop on a flat surface, battery side up.
    • Remove the two screws securing the RAM shield to the lower case.
    • The screws will remain captive within the shield.
    • Lift and remove the RAM shield up from the lower case.
  2. Use a pair of tweezers to disconnect both antennas from their sockets on the wireless card. Be careful to pull on the contacts and not the wires. The crimps used to hold them to the wires are delicate.
    • Use a pair of tweezers to disconnect both antennas from their sockets on the wireless card.
    • Be careful to pull on the contacts and not the wires. The crimps used to hold them to the wires are delicate.
  3. Remove the two 3.7 mm Phillips screws securing the wireless card to the motherboard.
    • Remove the two 3.7 mm Phillips screws securing the wireless card to the motherboard.
    • Upon removing the Phillips screws that secures the wireless card to the motherboard, the wireless card board should pop up from its top side.
    • Grasp the wireless card and pull it straight out of its socket on the motherboard.
  4. Wireless card remains.
    • Wireless card remains.
结论
4等其他人完成本指南。
Ben Hirsch
于2010年10月05日注册
3,709 信誉积分
创作了10篇指南
团队
Cal Poly, Team 21-33, Regan Fall 2010 Cal Poly, Team 21-33, Regan Fall 2010 的会员
CPSU-REGAN-F10S21G33
4 名成员
创作了10篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 13
总计 25,694
