跳转到主内容
HP Pavilion dv6000 Speaker Bar Replacement
你所需要的
  1. HP Pavilion dv6000 Speaker Bar Replacement, Speaker Bar: 步骤 1 中的图像 1,1
    • Make sure the laptop lid is closed, turn it over and remove the battery by moving the switch right to left.
    • there are three philips screws located on the surface where the writing is. remove those three screws.
  2. HP Pavilion dv6000 Speaker Bar Replacement: 步骤 2 中的图像 1,1
    • turn the laptop right side up. Between the cover and case on the top right of the laptop and using a plastic sludger or a finger lift gently on the speaker cover as to disengage the clips.
    • Be sure not to pull hard or you may damage the ribbon cables.
    • From the side closest to the screen turn the cover towards yourself.
  3. HP Pavilion dv6000 Speaker Bar Replacement: 步骤 3 中的图像 1,1
    • there is one connector from the speaker bar to a control board. Gently remove the cable.
    • There are two more screws attaching the speaker bar to the cover, remove these and take the speaker bar out.
  4. HP Pavilion dv6000 Speaker Bar Replacement: 步骤 4 中的图像 1,1
    • you are now ready to replace or repair the speaker bar. I recomend purchasing a new one, they range anywhere from 5-15 dollars online.
结论
5等其他人完成本指南。
Joba Fett
于04/11/14注册
227 声望
撰写一个指南
2条评论
how to fix speaker from board
kingsley Osunkwo - 回复
Grazie siete bravissimi . Ce ne fossero persone come voi che altruisticamente mettono a disposizione la loro esperienza di riparazioni per gli altri!
Fernando Mancini
fernando mancini - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 16
总计 3,460
