跳转到主内容
HP Pavilion dv6000 RAM Replacement
你所需要的
  1. HP Pavilion dv6000 RAM Replacement, RAM: 步骤 1 中的图像 1,3 HP Pavilion dv6000 RAM Replacement, RAM: 步骤 1 中的图像 2,3 HP Pavilion dv6000 RAM Replacement, RAM: 步骤 1 中的图像 3,3
    • Remove the two screws from the memory shield and lift up. The screws will remain into the shield
  2. HP Pavilion dv6000 RAM Replacement: 步骤 2 中的图像 1,3 HP Pavilion dv6000 RAM Replacement: 步骤 2 中的图像 2,3 HP Pavilion dv6000 RAM Replacement: 步骤 2 中的图像 3,3
    • Using a plastic spudger depress the pins holding the RAM in. If you have an anti-static work surface or wristband, you may suppress the pins with your thumbs.
    • Static charge built up on surfaces contacting the RAM or other computer components can damage and destroy the components. Always discharge yourself before handling these components!
    • Pull the RAM straight out.
  3. HP Pavilion dv6000 RAM Replacement: 步骤 3 中的图像 1,1
    • Under the first RAM stick is another. Remove it in the same way by pushing the silver tabs away and down from the RAM stick and remove the RAM once it pops up.
  4. HP Pavilion dv6000 RAM Replacement: 步骤 4 中的图像 1,1
    • You have removed your RAM!
    • If you want to expand your RAM you will have to use DDR2 PC2-5300 SODIMM laptop memory modules, they are clocked at 667MHz
    • To reinstall your RAM, follow this guide in the reverse order
结论
18等其他人完成本指南。
Ben Hirsch
于10/05/10注册
3,826 声望
创作了10篇指南
团队
Cal Poly, Team 21-33, Regan Fall 2010 Cal Poly, Team 21-33, Regan Fall 2010 的会员
CPSU-REGAN-F10S21G33
4 名成员
创作了12篇指南
3条评论
if you have bios version f.25 or newer you can have up to 4gb of ram
Bryce Stidman - 回复
2+2 or 4+4 ? which one?
Jes White -
That is pretty helpful. I think I am going to update my bios, not to mention the article forgot to mention to have a DDR2 ram. Just make sure to look for a DDR2 PC2- 5300 version with 667 MHz.
Tommy E. -
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 31
总计 34,694
