跳转到主内容
修复你的物品
维修的权力
配件 & 工具
简介
If you need more memory because your computer is running slowly, or you are having memory problems, the RAM is very easy to replace in the HP Pavilion dv6000.
  1. Remove the two screws from the memory shield and lift up.  The screws will remain into the shield Remove the two screws from the memory shield and lift up.  The screws will remain into the shield Remove the two screws from the memory shield and lift up.  The screws will remain into the shield
    • Remove the two screws from the memory shield and lift up. The screws will remain into the shield
  2. Using a plastic spudger depress the pins holding the RAM in. If you  have an anti-static work surface or wristband, you may suppress the pins with your thumbs. Static charge built up on surfaces contacting the RAM or other computer components can damage and destroy the components.  Always discharge yourself before handling these components! Pull the RAM straight out.
    • Using a plastic spudger depress the pins holding the RAM in. If you have an anti-static work surface or wristband, you may suppress the pins with your thumbs.
    • Static charge built up on surfaces contacting the RAM or other computer components can damage and destroy the components. Always discharge yourself before handling these components!
    • Pull the RAM straight out.
  3. LCD iPhone 屏幕维修套装
    预算选项,涵盖在我们的终身保修中。
    购买套装
    LCD iPhone 屏幕维修套装
    削减维修成本,而不是质量。
    购买套装
  4. Under the first RAM stick is another. Remove it in the same way by pushing the silver tabs away and down from the RAM stick and remove the RAM once it pops up.
    • Under the first RAM stick is another. Remove it in the same way by pushing the silver tabs away and down from the RAM stick and remove the RAM once it pops up.
  5. You have removed your RAM!
    • You have removed your RAM!
    • If you want to expand your RAM you will have to use PC2-5300 SODIMM laptop memory modules, they are clocked at 667MHz
    • To reinstall your RAM, follow this guide in the reverse order
结论
18等其他人完成本指南。
Ben Hirsch
于2010年10月05日注册
3,724 信誉积分
创作了10篇指南
团队
Cal Poly, Team 21-33, Regan Fall 2010 Cal Poly, Team 21-33, Regan Fall 2010 的会员
CPSU-REGAN-F10S21G33
4 名成员
创作了10篇指南
if you have bios version f.25 or newer you can have up to 4gb of ram
Bryce Stidman - 回复
2+2 or 4+4 ? which one?
Jes White -
添加评论
浏览统计数据:
过去的24小时: 2
过去的7天: 12
过去的30天: 50
总计 32,843
