简介
Replace the optical drive in your HP Pavilion dv6000.
配件
无需配件。
  1. Before proceeding, it is recommended to remove the battery to prevent any electrical damage to components.
    • Before proceeding, it is recommended to remove the battery to prevent any electrical damage to components.
    • Remove the single 5.6 mm Phillips screw securing the optical drive to the lower case.
  2. 所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
  3. Insert the tip of an unrolled paper clip into the small hole located on the side of the optical drive.
    • Insert the tip of an unrolled paper clip into the small hole located on the side of the optical drive.
    • The tray will partially pop out of the laptop.
    • Firmly pull the drive straight away from the laptop.
    • While pulling the drive out, be careful not to bend the sliding rails on both sides of the optical drive.
    • At this point you can remove the entire optical drive, or you can continue to disassemble the optical drive assembly.
结论
6等其他人完成本指南。
浏览统计数据:
过去的24小时: 1
过去的7天: 5
过去的30天: 23
总计 7,613
