当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Remove rubber screw covers from the LCD screen. The top covers pop off with a fingernail but the two on the bottom may require a screwdriver or flat tool.
Remove the six 7.15mm screws underneath the stoppers. There are four on top and two on bottom.
Press the tabs on the sides of the screen in and pop the plastic off. Careful, the plastic is very flimsy and may break.
Remove the two screws (5.8mm) on either side of the LCD near the hinge. Remove the screws on the outermost side first.
Take out the two 3.58mm screws on the LCD at the top (one on each edge).
Hold on to the LCD screen to prevent it from falling over and remove the two 3.58mm screws on the sides at the bottom.
Let the screen gently rest on the keyboard.
Remove the tape from the ribbon.
Stop here and check the cable
取消:我没有完成这个指南。
15等其他人完成本指南。
与8其他贡献者
于10/05/10注册
3,826 声望
创作了10篇指南
徽章: 15
+ 12更多徽章
CPSU-REGAN-F10S21G33
4 名成员
创作了12篇指南
after replacing my cracked screen the back light does not show again
firelionkofi - 2015年5月31日 回复
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 0
过去 7 天: 13
过去 30 天: 36
总计 39,315
