跳转到主内容
HP Pavilion dv6000 LCD Screen Replacement
你所需要的
  1. HP Pavilion dv6000 LCD Screen Replacement, LCD Screen: 步骤 1 中的图像 1,2 HP Pavilion dv6000 LCD Screen Replacement, LCD Screen: 步骤 1 中的图像 2,2
    • Remove rubber screw covers from the LCD screen. The top covers pop off with a fingernail but the two on the bottom may require a screwdriver or flat tool.
    • Remove the six 7.15mm screws underneath the stoppers. There are four on top and two on bottom.
  2. HP Pavilion dv6000 LCD Screen Replacement: 步骤 2 中的图像 1,2 HP Pavilion dv6000 LCD Screen Replacement: 步骤 2 中的图像 2,2
    • Press the tabs on the sides of the screen in and pop the plastic off. Careful, the plastic is very flimsy and may break.
  3. HP Pavilion dv6000 LCD Screen Replacement: 步骤 3 中的图像 1,2 HP Pavilion dv6000 LCD Screen Replacement: 步骤 3 中的图像 2,2
    • Remove the two screws (5.8mm) on either side of the LCD near the hinge. Remove the screws on the outermost side first.
  4. HP Pavilion dv6000 LCD Screen Replacement: 步骤 4 中的图像 1,2 HP Pavilion dv6000 LCD Screen Replacement: 步骤 4 中的图像 2,2
    • Take out the two 3.58mm screws on the LCD at the top (one on each edge).
  5. HP Pavilion dv6000 LCD Screen Replacement: 步骤 5 中的图像 1,1
    • Hold on to the LCD screen to prevent it from falling over and remove the two 3.58mm screws on the sides at the bottom.
  6. HP Pavilion dv6000 LCD Screen Replacement: 步骤 6 中的图像 1,3 HP Pavilion dv6000 LCD Screen Replacement: 步骤 6 中的图像 2,3 HP Pavilion dv6000 LCD Screen Replacement: 步骤 6 中的图像 3,3
    • Let the screen gently rest on the keyboard.
    • Remove the tape from the ribbon.
    • Stop here and check the cable
结论
15等其他人完成本指南。
Ben Hirsch
于10/05/10注册
3,826 声望
创作了10篇指南
团队
Cal Poly, Team 21-33, Regan Fall 2010 Cal Poly, Team 21-33, Regan Fall 2010 的会员
CPSU-REGAN-F10S21G33
4 名成员
创作了12篇指南
一条评论
after replacing my cracked screen the back light does not show again
firelionkofi - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 13
总计 39,270
