跳转到主内容
修复你的物品
维修的权力
配件 & 工具
简介
Replace the LCD in your HP Pavilion dv6000.
  1. Remove rubber screw covers from the LCD screen. The top covers pop off with a fingernail but the two on the bottom may require a screwdriver or flat tool. Remove the six 7.15mm screws underneath the stoppers. There are four on top and two on bottom.
    • Remove rubber screw covers from the LCD screen. The top covers pop off with a fingernail but the two on the bottom may require a screwdriver or flat tool.
    • Remove the six 7.15mm screws underneath the stoppers. There are four on top and two on bottom.
  2. Press the tabs on the sides of the screen in and pop the plastic off. Careful, the plastic is very flimsy and may break. Press the tabs on the sides of the screen in and pop the plastic off. Careful, the plastic is very flimsy and may break.
    • Press the tabs on the sides of the screen in and pop the plastic off. Careful, the plastic is very flimsy and may break.
  3. LCD iPhone 屏幕维修套装
    预算选项,涵盖在我们的终身保修中。
    购买套装
    LCD iPhone 屏幕维修套装
    削减维修成本,而不是质量。
    购买套装
  4. Remove the two screws (5.8mm) on either side of the LCD near the hinge. Remove the screws on the outermost side first. Remove the two screws (5.8mm) on either side of the LCD near the hinge. Remove the screws on the outermost side first.
    • Remove the two screws (5.8mm) on either side of the LCD near the hinge. Remove the screws on the outermost side first.
  5. Take out the two 3.58mm screws on the LCD at the top (one on each edge). Take out the two 3.58mm screws on the LCD at the top (one on each edge).
    • Take out the two 3.58mm screws on the LCD at the top (one on each edge).
  6. Hold on to the LCD screen to prevent it from falling over and remove the two 3.58mm screws on the sides at the bottom.
    • Hold on to the LCD screen to prevent it from falling over and remove the two 3.58mm screws on the sides at the bottom.
  7. Let the screen gently rest on the keyboard. Remove the tape from the ribbon. Stop here and check the cable
    • Let the screen gently rest on the keyboard.
    • Remove the tape from the ribbon.
    • Stop here and check the cable
结论
15等其他人完成本指南。
Ben Hirsch
于2010年10月05日注册
3,724 信誉积分
创作了10篇指南
团队
Cal Poly, Team 21-33, Regan Fall 2010 Cal Poly, Team 21-33, Regan Fall 2010 的会员
CPSU-REGAN-F10S21G33
4 名成员
创作了10篇指南
after replacing my cracked screen the back light does not show again
firelionkofi - 回复
添加评论
浏览统计数据:
过去的24小时: 3
过去的7天: 14
过去的30天: 54
总计 37,409
