跳转到主内容
HP Pavilion dv6000 Hard Drive Replacement
你所需要的
  1. HP Pavilion dv6000 Hard Drive Replacement, Hard Drive: 步骤 1 中的图像 1,2 HP Pavilion dv6000 Hard Drive Replacement, Hard Drive: 步骤 1 中的图像 2,2
    • Remove the two screws from the hard drive shield and lift it off starting at the right side. The screws will remain in the shield.
    this was very unexpected place to find the answer to my dilemma being unable to figure this hp silliness out; for a couple of months i sat on the upgrade of this almost unusable laptop. i was going to just list it as mostly junk on ebay. all it was is a stupid hp ssd adapter!? i kept looking for an adapter to go the other way unaware it was already there that is why it did not make sense! im trying not to scream! anyway thanks to this wonderful site my laptop is now much more ready to sell as vintage. all it took was a simple photo and sentence "remove the adapter from the hdd"!
    D C Gubler - 回复
  2. HP Pavilion dv6000 Hard Drive Replacement: 步骤 2 中的图像 1,2 HP Pavilion dv6000 Hard Drive Replacement: 步骤 2 中的图像 2,2
    • Pull the plastic tab attached to the hard drive. The hard drive lifts right out. Pull gently so you don't damage the contacts.
  3. HP Pavilion dv6000 Hard Drive Replacement: 步骤 3 中的图像 1,2 HP Pavilion dv6000 Hard Drive Replacement: 步骤 3 中的图像 2,2
    • Now you have your hard drive out!
  4. HP Pavilion dv6000 Hard Drive Replacement: 步骤 4 中的图像 1,2 HP Pavilion dv6000 Hard Drive Replacement: 步骤 4 中的图像 2,2
    • Gently pull forward the HP adapter from the top of the hard drive.
    • Insert the adapter onto the new SATA hard drive, to be replaced in the laptop.
结论
19等其他人完成本指南。
Ben Hirsch
于10/05/10注册
3,826 声望
创作了10篇指南
团队
Cal Poly, Team 21-33, Regan Fall 2010 Cal Poly, Team 21-33, Regan Fall 2010 的会员
CPSU-REGAN-F10S21G33
4 名成员
创作了12篇指南
2条评论
thanks for your help
moyguens - 回复
I was scratching my head when I recvd the new hd w/out the adapter... LOL! thanks
gilaraujog - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 37
总计 41,201
