本指南有最近更改,您可查看未经巡查的最新版本。
简介
If the camera on your HP Pavilion dv6000 needs to be repaired, follow this guide.
你所需要的
Remove rubber screw covers from the LCD screen. They cover the screws. The stops on the top of the screen pop off, but the lower covers require a screwdriver to remove.
If you need to use the screwdriver to remove the rubber screw covers, gently push the screwdriver down the edge of the stopper and then use the screwdriver as a lever to pry the cover from the hole.
Remove the six 7.15mm screws underneath the stoppers. There are four on top and two on bottom.
3等其他人完成本指南。
