跳转到主内容
HP Pavilion dv6000 Camera Replacement
你所需要的
  1. HP Pavilion dv6000 Camera Replacement, Camera: 步骤 1 中的图像 1,2 HP Pavilion dv6000 Camera Replacement, Camera: 步骤 1 中的图像 2,2
    • Remove rubber screw covers from the LCD screen. They cover the screws. The stops on the top of the screen pop off, but the lower covers require a screwdriver to remove.
    • If you need to use the screwdriver to remove the rubber screw covers, gently push the screwdriver down the edge of the stopper and then use the screwdriver as a lever to pry the cover from the hole.
    • Remove the six 7.15mm screws underneath the stoppers. There are four on top and two on bottom.
  2. HP Pavilion dv6000 Camera Replacement: 步骤 2 中的图像 1,3 HP Pavilion dv6000 Camera Replacement: 步骤 2 中的图像 2,3 HP Pavilion dv6000 Camera Replacement: 步骤 2 中的图像 3,3
    • Press the tabs in on the sides of the screen and pop the plastic covering off.
    • The edges of the LCD screen are very sharp. Take care to not cut your fingers!
  3. HP Pavilion dv6000 Camera Replacement: 步骤 3 中的图像 1,1
    • Lift the screen out of the casing at the top near the camera.
    • Take care to not snap the plastic casing! It is brittle and still attached to the bottom of the screen.
  4. HP Pavilion dv6000 Camera Replacement: 步骤 4 中的图像 1,1
    • Gently remove the main cable from the camera.
  5. HP Pavilion dv6000 Camera Replacement: 步骤 5 中的图像 1,2 HP Pavilion dv6000 Camera Replacement: 步骤 5 中的图像 2,2
    • There are three clasps holding the camera down. Gingerly lift the camera board up, being careful not to snap the board, clasps, or vertical plastic pins (inside the gold-colored rings).
    • The metal tabs to the left and right of the camera (for the LCD) are sharp, watch your fingers!
  6. HP Pavilion dv6000 Camera Replacement: 步骤 6 中的图像 1,1
    • Remove the camera unit from the laptop and you are done!
结论
3等其他人完成本指南。
Ben Hirsch
于10/05/10注册
3,853 声望
创作了10篇指南
团队
Cal Poly, Team 21-33, Regan Fall 2010 Cal Poly, Team 21-33, Regan Fall 2010 的会员
CPSU-REGAN-F10S21G33
4 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 16
总计 10,143
