跳转到主内容
简介
If the camera on your HP Pavilion dv6000 needs to be repaired, follow this guide.
配件
没有特定配件。
  1. Remove rubber screw covers from the LCD screen. They cover the screws. The stops on the top of the screen pop off, but the lower covers require a screwdriver to remove. If you need to use the screwdriver to remove the rubber screw covers, gently push the screwdriver down the edge of the stopper and then use the screwdriver as a lever to pry the cover from the hole.
    • Remove rubber screw covers from the LCD screen. They cover the screws. The stops on the top of the screen pop off, but the lower covers require a screwdriver to remove.
    • If you need to use the screwdriver to remove the rubber screw covers, gently push the screwdriver down the edge of the stopper and then use the screwdriver as a lever to pry the cover from the hole.
    • Remove the six 7.15mm screws underneath the stoppers. There are four on top and two on bottom.
  2. Press the tabs in on the sides of the screen and pop the plastic covering off. The edges of the LCD screen are very sharp.  Take care to not cut your fingers! The edges of the LCD screen are very sharp.  Take care to not cut your fingers!
    • Press the tabs in on the sides of the screen and pop the plastic covering off.
    • The edges of the LCD screen are very sharp. Take care to not cut your fingers!
  3. Lift the screen out of the casing at the top near the camera.
    • Lift the screen out of the casing at the top near the camera.
    • Take care to not snap the plastic casing! It is brittle and still attached to the bottom of the screen.
  4. Gently remove the main cable from the camera.
    • Gently remove the main cable from the camera.
  5. There are three clasps holding the camera down.  Gingerly lift the camera board up, being careful not to snap the board, clasps, or vertical plastic pins (inside the gold-colored rings). The metal tabs to the left and right of the camera (for the LCD) are sharp, watch your fingers!
    • There are three clasps holding the camera down. Gingerly lift the camera board up, being careful not to snap the board, clasps, or vertical plastic pins (inside the gold-colored rings).
    • The metal tabs to the left and right of the camera (for the LCD) are sharp, watch your fingers!
  6. Remove the camera unit from the laptop and you are done!
    • Remove the camera unit from the laptop and you are done!
结论
2等其他人完成本指南。
Ben Hirsch
于2010年10月05日注册
3,688 信誉积分
创作了10篇指南
团队
Cal Poly, Team 21-33, Regan Fall 2010 Cal Poly, Team 21-33, Regan Fall 2010 的会员
CPSU-REGAN-F10S21G33
4 名成员
创作了10篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 3
过去的30天: 11
总计 8,869
