跳转到主内容
HP Pavilion dv6-6180us Speaker Replacement
你所需要的
  1. HP Pavilion dv6-6180us Speaker Replacement, Hard Drive: 步骤 1 中的图像 1,1
    • Turn off and unplug the device before starting.
    • Flip your device over so the bottom panel is facing up.
  2. HP Pavilion dv6-6180us Speaker Replacement: 步骤 2 中的图像 1,1
    • Slide the lock switch to the right.
    • The panel will pop open at the top corner.
  3. HP Pavilion dv6-6180us Speaker Replacement: 步骤 3 中的图像 1,1
    • Use the plastic opening tool to remove the back panel.
    • Some force may be required to remove the panel from the case. Use caution when prying to avoid breaking the panel or the plastic tabs securing it in place.
  4. HP Pavilion dv6-6180us Speaker Replacement: 步骤 4 中的图像 1,1
    • Use the PH 1 screwdriver to remove the four 3.5 mm screws securing the hard drive.
  5. HP Pavilion dv6-6180us Speaker Replacement: 步骤 5 中的图像 1,1
    • Lift the corner bracket to remove the hard drive.
  6. HP Pavilion dv6-6180us Speaker Replacement: 步骤 6 中的图像 1,1
    • Unplug the hard drive wire to detach the hard drive.
  7. HP Pavilion dv6-6180us Speaker Replacement, Speaker: 步骤 7 中的图像 1,1
    • Unscrew four 3.5 mm screws from the inside of the battery compartment with PH 1 screwdriver.
    • Unscrew nine 5 mm screws with PH 1 screwdriver.
    • Unscrew four 4 mm screws with PH 1 screwdriver.
  8. HP Pavilion dv6-6180us Speaker Replacement: 步骤 8 中的图像 1,1
    • Flip right-side up and open the laptop.
    • Pry open the keyboard using plastic opening tool starting from the top.
    • Lift up keyboard gently,as a silver ribbon is still attaching it to the laptop
  9. HP Pavilion dv6-6180us Speaker Replacement: 步骤 9 中的图像 1,1
    • Place keyboard upside down.
    • Lift up plastic cover over keyboard ribbon cable.
    • Pull ribbon cable up away from keyboard to completely remove.
  10. HP Pavilion dv6-6180us Speaker Replacement: 步骤 10 中的图像 1,1
    • Remove seven 4mm pannel screws with PH 1 screwdriver.
  11. HP Pavilion dv6-6180us Speaker Replacement: 步骤 11 中的图像 1,1
    • Put the computer on its side
    • Separate top panel from bottom frame.
  12. HP Pavilion dv6-6180us Speaker Replacement: 步骤 12 中的图像 1,1
    • Pop open palm rest panel.
  13. HP Pavilion dv6-6180us Speaker Replacement: 步骤 13 中的图像 1,1
    • Pull ribbon to detach from bottom panel.
  14. HP Pavilion dv6-6180us Speaker Replacement: 步骤 14 中的图像 1,2 HP Pavilion dv6-6180us Speaker Replacement: 步骤 14 中的图像 2,2
    • Lift up speaker.
  15. HP Pavilion dv6-6180us Speaker Replacement: 步骤 15 中的图像 1,1
    • Lift up white panel covering speaker ribbon cable.
  16. HP Pavilion dv6-6180us Speaker Replacement: 步骤 16 中的图像 1,1
    • Pull out the speaker ribbon.
  17. HP Pavilion dv6-6180us Speaker Replacement: 步骤 17 中的图像 1,2 HP Pavilion dv6-6180us Speaker Replacement: 步骤 17 中的图像 2,2
    • Unhook speaker cable from hooks.
  18. HP Pavilion dv6-6180us Speaker Replacement: 步骤 18 中的图像 1,1
    • Pull out silver wire to reveal black speaker wire.
  19. HP Pavilion dv6-6180us Speaker Replacement: 步骤 19 中的图像 1,1
    • Unplug the red, white, and black speaker wire connector.
结论
2等其他人完成本指南。
michelle pulido
于09/15/16注册
859 声望
创作了4篇指南
团队
CSU Fullerton, Team 1-2, Bruce Fall 2016 CSU Fullerton, Team 1-2, Bruce Fall 2016 的会员
CSUF-BRUCE-F16S1G2
4 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 36
总计 2,530
