跳转到主内容
HP Pavilion dv6-6180us Screen Replacement
你所需要的
  1. HP Pavilion dv6-6180us Screen Replacement, Hard Drive: 步骤 1 中的图像 1,1
    • Turn off and unplug the device before starting.
    • Flip your device over so the bottom panel is facing up.
  2. HP Pavilion dv6-6180us Screen Replacement: 步骤 2 中的图像 1,1
    • Slide the lock switch to the right.
    • The panel will pop open at the top corner.
  3. HP Pavilion dv6-6180us Screen Replacement: 步骤 3 中的图像 1,1
    • Use the plastic opening tool to remove the back panel.
    • Some force may be required to remove the panel from the case. Use caution when prying to avoid breaking the panel or the plastic tabs securing it in place.
  4. HP Pavilion dv6-6180us Screen Replacement: 步骤 4 中的图像 1,1
    • Use the PH 1 screwdriver to remove the four 3.5 mm screws securing the hard drive.
  5. HP Pavilion dv6-6180us Screen Replacement: 步骤 5 中的图像 1,1
    • Lift the corner bracket to remove the hard drive.
  6. HP Pavilion dv6-6180us Screen Replacement: 步骤 6 中的图像 1,1
    • Unplug the hard drive wire to detach the hard drive.
  7. HP Pavilion dv6-6180us Screen Replacement, Screen: 步骤 7 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Using tweezers, grab the top and bottom while rocking back and forth to pull rubber plug out.
    • Cover is glued into place so gently pick at the edge before removing.
  8. HP Pavilion dv6-6180us Screen Replacement: 步骤 8 中的图像 1,1
    • Unscrew two 6mm screws using PH1 screwdriver.
  9. HP Pavilion dv6-6180us Screen Replacement: 步骤 9 中的图像 1,1
    • Pry the left lower corner with fingers.
  10. HP Pavilion dv6-6180us Screen Replacement: 步骤 10 中的图像 1,1
    • Remove screen frame.
  11. HP Pavilion dv6-6180us Screen Replacement: 步骤 11 中的图像 1,2 HP Pavilion dv6-6180us Screen Replacement: 步骤 11 中的图像 2,2
    • Unscrew two 3mm screws using PH 1 screwdriver
    • Eight 6mm screws using PH 1 screwdriver.
    • Use PH 000 screwdriver to remove two 4mm screws.
  12. HP Pavilion dv6-6180us Screen Replacement: 步骤 12 中的图像 1,1
    • Pry open the keyboard using plastic opening tool starting from the top.
    • Lift up keyboard gently because a silver ribbon is still attaching it to the laptop.
  13. HP Pavilion dv6-6180us Screen Replacement: 步骤 13 中的图像 1,3 HP Pavilion dv6-6180us Screen Replacement: 步骤 13 中的图像 2,3 HP Pavilion dv6-6180us Screen Replacement: 步骤 13 中的图像 3,3
    • Place keyboard upside down.
    • Lift up plastic cover over keyboard connector cable.
    • Pull ribbon cable up away from keyboard to completely remove.
  14. HP Pavilion dv6-6180us Screen Replacement: 步骤 14 中的图像 1,1
    • Remove seven 4mm pannel screws with PH 1 screwdriver.
  15. HP Pavilion dv6-6180us Screen Replacement: 步骤 15 中的图像 1,1
    • Place the computer on its side.
    • Separate top panel from bottom frame.
  16. HP Pavilion dv6-6180us Screen Replacement: 步骤 16 中的图像 1,2 HP Pavilion dv6-6180us Screen Replacement: 步骤 16 中的图像 2,2
    • Pop open rest palm assembly.
  17. HP Pavilion dv6-6180us Screen Replacement: 步骤 17 中的图像 1,1
    • Pull ribbon to detach from bottom panel.
  18. HP Pavilion dv6-6180us Screen Replacement: 步骤 18 中的图像 1,1
    • Remove two 5mm screws securing fan, using HP 1 screwdriver.
  19. HP Pavilion dv6-6180us Screen Replacement: 步骤 19 中的图像 1,1
    • Flip laptop over.
    • Remove two 4mm screws securing antenna using PH 1 screwdriver.
    • Pull antenna to the right to remove.
  20. HP Pavilion dv6-6180us Screen Replacement: 步骤 20 中的图像 1,1
    • Flip laptop side up.
    • Pull off yellow insulating tape.
  21. HP Pavilion dv6-6180us Screen Replacement: 步骤 21 中的图像 1,2 HP Pavilion dv6-6180us Screen Replacement: 步骤 21 中的图像 2,2
    • Grab tab on left top corner and remove black wire.
    • Remove white input attachment.
  22. HP Pavilion dv6-6180us Screen Replacement: 步骤 22 中的图像 1,1
    • Lift up speaker.
  23. HP Pavilion dv6-6180us Screen Replacement: 步骤 23 中的图像 1,1
    • Hold the motherboard and pull to the right.
    • The plugs on the left may be difficult to snap out.
  24. HP Pavilion dv6-6180us Screen Replacement: 步骤 24 中的图像 1,1
    • Remove a 4mm screw securing wire attachment using PH 1 screwdriver.
  25. HP Pavilion dv6-6180us Screen Replacement: 步骤 25 中的图像 1,1
    • Remove two hinge covers.
  26. HP Pavilion dv6-6180us Screen Replacement: 步骤 26 中的图像 1,1
    • Unhook the antenna wire from behind hinge.
  27. HP Pavilion dv6-6180us Screen Replacement: 步骤 27 中的图像 1,1
    • Lay screen face down.
    • Detach silver wire from screen
结论
另外一个人完成了本指南。
michelle pulido
于09/15/16注册
859 声望
创作了4篇指南
团队
CSU Fullerton, Team 1-2, Bruce Fall 2016 CSU Fullerton, Team 1-2, Bruce Fall 2016 的会员
CSUF-BRUCE-F16S1G2
4 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 12
过去 30 天: 30
总计 1,585
