跳转到主内容
HP Pavilion dv6-6180us Hard Drive Replacement
你所需要的
  1. HP Pavilion dv6-6180us Hard Drive  Replacement, Hard Drive: 步骤 1 中的图像 1,1
    • Turn off and unplug the device before starting.
    • Flip your device over so the bottom panel is facing up.
  2. HP Pavilion dv6-6180us Hard Drive  Replacement: 步骤 2 中的图像 1,1
    • Slide the lock switch to the right.
    • The panel will pop open at the top corner.
  3. HP Pavilion dv6-6180us Hard Drive  Replacement: 步骤 3 中的图像 1,1
    • Use the plastic opening tool to remove the back panel.
    • Some force may be required to remove the panel from the case. Use caution when prying to avoid breaking the panel or the plastic tabs securing it in place.
  4. HP Pavilion dv6-6180us Hard Drive  Replacement: 步骤 4 中的图像 1,1
    • Use the PH 1 screwdriver to remove the four 3.5 mm screws securing the hard drive.
  5. HP Pavilion dv6-6180us Hard Drive  Replacement: 步骤 5 中的图像 1,1
    • Lift the corner bracket to remove the hard drive.
  6. HP Pavilion dv6-6180us Hard Drive  Replacement: 步骤 6 中的图像 1,1
    • Unplug the hard drive wire to detach the hard drive.
结论
5等其他人完成本指南。
michelle pulido
于09/15/16注册
859 声望
创作了4篇指南
团队
CSU Fullerton, Team 1-2, Bruce Fall 2016 CSU Fullerton, Team 1-2, Bruce Fall 2016 的会员
CSUF-BRUCE-F16S1G2
4 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 18
总计 1,796
