简介
Are you unable to connect to WiFi? Your WiFi adapter may be broken. This guide will walk you through replacing it with a new, working WiFi adapter, with only a spudger and a Phillips #0 screw driver. Once you have a clean work space and the tools required, follow the steps below.
你所需要的
Begin removing the bottom cover by sliding the battery removal slider to the right to pop off the top of the cover.
2等其他人完成本指南。
