跳转到主内容
HP Pavilion dv6-6117dx RAM Replacement
你所需要的
  1. HP Pavilion dv6-6117dx RAM Replacement, RAM: 步骤 1 中的图像 1,2 HP Pavilion dv6-6117dx RAM Replacement, RAM: 步骤 1 中的图像 2,2
    • Begin removing the bottom cover by sliding the battery removal slider to the right to pop off the top of the cover.
  2. HP Pavilion dv6-6117dx RAM Replacement: 步骤 2 中的图像 1,2 HP Pavilion dv6-6117dx RAM Replacement: 步骤 2 中的图像 2,2
    • Slide a black spudger under the top of the cover to loosen the clips underneath.
  3. HP Pavilion dv6-6117dx RAM Replacement: 步骤 3 中的图像 1,3 HP Pavilion dv6-6117dx RAM Replacement: 步骤 3 中的图像 2,3 HP Pavilion dv6-6117dx RAM Replacement: 步骤 3 中的图像 3,3
    • Slide the spudger down the left side of the cover to loosen the clips.
    • After the left side is loose, the rest of the cover should pop off, and you can remove it with your hands.
    • When reassembling, insert the bottom of the cover first, and then firmly press along the edges from bottom to top to secure it in place.
  4. HP Pavilion dv6-6117dx RAM Replacement: 步骤 4 中的图像 1,2 HP Pavilion dv6-6117dx RAM Replacement: 步骤 4 中的图像 2,2
    • Push the tabs on both sides away from each other to free the RAM, which will raise to a 45º angle.
  5. HP Pavilion dv6-6117dx RAM Replacement: 步骤 5 中的图像 1,2 HP Pavilion dv6-6117dx RAM Replacement: 步骤 5 中的图像 2,2
    • Always handle RAM by the edges to avoid damaging the part.
    • Remove the RAM by grabbing it by the sides and pulling out at a 45º angle.
    • When inserting the new stick of RAM, you should insert it at this same angle.
结论
Joshua Holme
于03/19/18注册
765 声望
创作了4篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 6
过去 30 天: 22
总计 737
