跳转到主内容
HP Pavilion dv6-6117dx Hard Drive Replacement
你所需要的
  1. HP Pavilion dv6-6117dx Hard Drive Replacement, Hard Drive: 步骤 1 中的图像 1,2 HP Pavilion dv6-6117dx Hard Drive Replacement, Hard Drive: 步骤 1 中的图像 2,2
    • Begin removing the bottom cover by sliding the battery removal slider to the right to pop off the top of the cover.
  2. HP Pavilion dv6-6117dx Hard Drive Replacement: 步骤 2 中的图像 1,2 HP Pavilion dv6-6117dx Hard Drive Replacement: 步骤 2 中的图像 2,2
    • Slide a black spudger under the top of the cover to loosen the clips underneath.
  3. HP Pavilion dv6-6117dx Hard Drive Replacement: 步骤 3 中的图像 1,3 HP Pavilion dv6-6117dx Hard Drive Replacement: 步骤 3 中的图像 2,3 HP Pavilion dv6-6117dx Hard Drive Replacement: 步骤 3 中的图像 3,3
    • Slide the spudger down the left side of the cover to loosen the clips.
    • After the left side is loose, the rest of the cover should pop off, and you can remove it with your hands.
    • When reassembling, insert the bottom of the cover first, and then firmly press along the edges from bottom to top to secure it in place.
  4. HP Pavilion dv6-6117dx Hard Drive Replacement: 步骤 4 中的图像 1,3 HP Pavilion dv6-6117dx Hard Drive Replacement: 步骤 4 中的图像 2,3 HP Pavilion dv6-6117dx Hard Drive Replacement: 步骤 4 中的图像 3,3
    • Using a Phillips #0 screw driver, remove the four 4mm screws holding the hard drive in place.
  5. HP Pavilion dv6-6117dx Hard Drive Replacement: 步骤 5 中的图像 1,3 HP Pavilion dv6-6117dx Hard Drive Replacement: 步骤 5 中的图像 2,3 HP Pavilion dv6-6117dx Hard Drive Replacement: 步骤 5 中的图像 3,3
    • Using a plastic spudger, lift up the hard drive from the top left corner and flip it to the right of the laptop like opening a book.
    • There is a cable connecting the hard drive to the laptop, be sure not to pull it out when flipping the hard drive.
  6. HP Pavilion dv6-6117dx Hard Drive Replacement: 步骤 6 中的图像 1,2 HP Pavilion dv6-6117dx Hard Drive Replacement: 步骤 6 中的图像 2,2
    • Pull the tab at the end of the cable connecting the hard drive to the laptop.
  7. HP Pavilion dv6-6117dx Hard Drive Replacement: 步骤 7 中的图像 1,3 HP Pavilion dv6-6117dx Hard Drive Replacement: 步骤 7 中的图像 2,3 HP Pavilion dv6-6117dx Hard Drive Replacement: 步骤 7 中的图像 3,3
    • Using a Phillips #0 screw driver, remove the four 4mm screws on each side of the hard drive attaching it to its carriage.
  8. HP Pavilion dv6-6117dx Hard Drive Replacement: 步骤 8 中的图像 1,2 HP Pavilion dv6-6117dx Hard Drive Replacement: 步骤 8 中的图像 2,2
    • Remove the hard drive from its carriage.
  9. HP Pavilion dv6-6117dx Hard Drive Replacement: 步骤 9 中的图像 1,2 HP Pavilion dv6-6117dx Hard Drive Replacement: 步骤 9 中的图像 2,2
    • Remove the SATA cable from the hard drive.
结论
4等其他人完成本指南。
Joshua Holme
于03/19/18注册
765 声望
创作了4篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 10
过去 30 天: 43
总计 2,535
