跳转到主内容
HP Pavilion dv6-2158nr Speaker Assembly Replacement
你所需要的
  1. HP Pavilion dv6-2158nr Speaker Assembly Replacement, Battery: 步骤 1 中的图像 1,3 HP Pavilion dv6-2158nr Speaker Assembly Replacement, Battery: 步骤 1 中的图像 2,3 HP Pavilion dv6-2158nr Speaker Assembly Replacement, Battery: 步骤 1 中的图像 3,3
    • Locate the battery on the bottom side of the laptop.
    • Slide the release switch and the battery will pop out.
    • Remove the battery
  2. HP Pavilion dv6-2158nr Speaker Assembly Replacement, Keyboard: 步骤 2 中的图像 1,3 HP Pavilion dv6-2158nr Speaker Assembly Replacement, Keyboard: 步骤 2 中的图像 2,3 HP Pavilion dv6-2158nr Speaker Assembly Replacement, Keyboard: 步骤 2 中的图像 3,3
    • Using a Philips #1 Loosen the three 7mm captive screws that secure the memory module compartment cover to the computer.
    • Lift the rear edge of the cover, swing it up and to the front, and remove the cover.
  3. HP Pavilion dv6-2158nr Speaker Assembly Replacement: 步骤 3 中的图像 1,2 HP Pavilion dv6-2158nr Speaker Assembly Replacement: 步骤 3 中的图像 2,2
    • Loosen the two 6mm captive screws that secure the hard drive port bezel cover to the computer, using a Philips #1.
    • Lift the right side of the hard drive port bezel cover, swing it up and to the left, and remove the cover.
  4. HP Pavilion dv6-2158nr Speaker Assembly Replacement: 步骤 4 中的图像 1,3 HP Pavilion dv6-2158nr Speaker Assembly Replacement: 步骤 4 中的图像 2,3 HP Pavilion dv6-2158nr Speaker Assembly Replacement: 步骤 4 中的图像 3,3
    • Use the Mylar tab to lift the hard drive up, and then slide it to the left to release it from the hard drive bay.
  5. HP Pavilion dv6-2158nr Speaker Assembly Replacement: 步骤 5 中的图像 1,2 HP Pavilion dv6-2158nr Speaker Assembly Replacement: 步骤 5 中的图像 2,2
    • Disconnect the hard drive cable from the system board.
    • Remove the hard drive from the hard drive bay and set it aside.
  6. HP Pavilion dv6-2158nr Speaker Assembly Replacement: 步骤 6 中的图像 1,2 HP Pavilion dv6-2158nr Speaker Assembly Replacement: 步骤 6 中的图像 2,2
    • With laptop upside down locate the three sets of screws that fasten the keyboard and switch cover.
    • Two Phillips 7mm screws that secure the switch cover to the computer.
    • Four Phillips 4.0mm screws that secure the switch cover to the computer. (these are inside the battery bay)
    • Four Philips 7mm screws that secure the keyboard to the computer.
    • Remove all ten screws.
  7. HP Pavilion dv6-2158nr Speaker Assembly Replacement: 步骤 7 中的图像 1,2 HP Pavilion dv6-2158nr Speaker Assembly Replacement: 步骤 7 中的图像 2,2
    • Turn the computer over, and locate the Switch Cover.
    • Using the Safe Pry Tool, un-clip the Switch Cover until it detaches from the computer.
    • The clips will need careful prying to unhook.
  8. HP Pavilion dv6-2158nr Speaker Assembly Replacement: 步骤 8 中的图像 1,3 HP Pavilion dv6-2158nr Speaker Assembly Replacement: 步骤 8 中的图像 2,3 HP Pavilion dv6-2158nr Speaker Assembly Replacement: 步骤 8 中的图像 3,3
    • Slide the Switch Cover onto the LCD Monitor, exposing the Speaker Assembly.
    • There are two ribbon cables still attached to the speaker assembly
    • Detach the two ribbon cables from the speaker assembly.
  9. HP Pavilion dv6-2158nr Speaker Assembly Replacement: 步骤 9 中的图像 1,3 HP Pavilion dv6-2158nr Speaker Assembly Replacement: 步骤 9 中的图像 2,3 HP Pavilion dv6-2158nr Speaker Assembly Replacement: 步骤 9 中的图像 3,3
    • Remove the three silver Phillips 3.5mm screws that secure the keyboard to the computer.
    • Lift the rear edge of the keyboard and slide the keyboard back until the keyboard connector on the system board is accessible.
  10. HP Pavilion dv6-2158nr Speaker Assembly Replacement: 步骤 10 中的图像 1,3 HP Pavilion dv6-2158nr Speaker Assembly Replacement: 步骤 10 中的图像 2,3 HP Pavilion dv6-2158nr Speaker Assembly Replacement: 步骤 10 中的图像 3,3
    • Unhinge the zero insertion force (ZIF) connector to release the ribbon cable then pull gently on the cable to release.
    • You need to unhinge the blue plastic to release the ribbon cable from the main board.
    • The keyboard can now be lifted off and set aside.
  11. HP Pavilion dv6-2158nr Speaker Assembly Replacement, Speaker Assembly: 步骤 11 中的图像 1,2 HP Pavilion dv6-2158nr Speaker Assembly Replacement, Speaker Assembly: 步骤 11 中的图像 2,2
    • Position the computer with the keyboard facing up its front edge toward you.
    • Disconnect the speaker cable from the system board.
  12. HP Pavilion dv6-2158nr Speaker Assembly Replacement: 步骤 12 中的图像 1,2 HP Pavilion dv6-2158nr Speaker Assembly Replacement: 步骤 12 中的图像 2,2
    • Using the Phillips #1 screwdriver, remove the four Phillips 4mm screws that secure the speaker assembly.
    • You will also need the Phillips #1 screwdriver to remove the Phillips 7mm screw that secures the center of the speaker assembly.
    • Remove the speaker assembly from the computer.
结论
2等其他人完成本指南。
Chad
于01/13/14注册
1,123 声望
创作了6篇指南
团队
Cal Poly, Team 10-34, Maness Winter 2014 Cal Poly, Team 10-34, Maness Winter 2014 的会员
CPSU-MANESS-W14S10G34
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 17
总计 2,947
