跳转到主内容
HP Pavilion dv6-2155dx Hard Drive Replacement
你所需要的
  1. HP Pavilion dv6-2155dx Hard Drive Replacement, Hard Drive: 步骤 1 中的图像 1,2 HP Pavilion dv6-2155dx Hard Drive Replacement, Hard Drive: 步骤 1 中的图像 2,2
    • Shutdown your computer and remove the battery before beginning the replacement.
    • Loosen the screws using Phillips #01 screwdriver with the extension attached.
    • The screws will not come out completely but stay on the panel.
  2. HP Pavilion dv6-2155dx Hard Drive Replacement: 步骤 2 中的图像 1,1
    • After removing the two screws securing the Hard Drive to the bottom case, remove the panel to reveal the hard drive.
  3. HP Pavilion dv6-2155dx Hard Drive Replacement: 步骤 3 中的图像 1,2 HP Pavilion dv6-2155dx Hard Drive Replacement: 步骤 3 中的图像 2,2
    • Locate the tab of the black Mylar film on the right hand side of the hard drive.
    • Gently grip it with your thumb and index finger.
  4. HP Pavilion dv6-2155dx Hard Drive Replacement: 步骤 4 中的图像 1,2 HP Pavilion dv6-2155dx Hard Drive Replacement: 步骤 4 中的图像 2,2
    • Pull the Hard Drive to the right to loosen the it from the frame.
    • The left side of the hard drive will pop up and should slide out freely until you see the black connector on it's right side, connecting it to the computer.
  5. HP Pavilion dv6-2155dx Hard Drive Replacement: 步骤 5 中的图像 1,2 HP Pavilion dv6-2155dx Hard Drive Replacement: 步骤 5 中的图像 2,2
    • When removing the Hard Drive from the frame, you will see a black connector on it's right side.
    • Turn the Hard Drive over and grasp the Hard Drive with one hand as you grip the connector with the other hand to remove the connector from the hard drive.
    • To safely remove the Hard Driver, do not wiggle or jerk the connector off of the Hard Drive, pull straight off.
结论
Lisa Redder
于10/18/16注册
318 声望
撰写一个指南
团队
UMass Dartmouth, Team 2-2, Isaacson Fall 2016 UMass Dartmouth, Team 2-2, Isaacson Fall 2016 的会员
UMASSD-ISAACSON-F16S2G2
3 名成员
创作了5篇指南
一条评论
Can I transfer the information on the hard drive to another computer? How? My laptop won’t turn on and I’ve tried everything.
Sheree Norton - 回复
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 7
过去 30 天: 26
总计 1,867
