当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Remove the first memory module by spreading apart the two silver retaining tabs, using your thumb and index finger.
Pull and lift the green memory module upward at a 45-degree angle, and then pull the memory module out of the computer.
If you are replacing both memory cards, repeat this step with the bottom memory card.
To replace the memory card, insert the card at a 45-degree angle, then push into slot.
Push down gently so the silver retaining tabs click back into place.
If you are replacing both memory cards, replace the bottom card (closest to the system board) first.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
