跳转到主内容
HP Pavilion dv6-1245dx RAM Replacement
你所需要的
  1. HP Pavilion dv6-1245dx RAM Replacement, RAM: 步骤 1 中的图像 1,1
    • Shut down the computer and unplug it from the outlet.
    • All screws removed in this guide will require a Phillips #00 screwdriver.
  2. HP Pavilion dv6-1245dx RAM Replacement: 步骤 2 中的图像 1,1
    • Turn the computer upside down.
  3. HP Pavilion dv6-1245dx RAM Replacement: 步骤 3 中的图像 1,1
    • Loosen the three screws from the memory module compartment cover
    • Screws will not come all the way out.
  4. HP Pavilion dv6-1245dx RAM Replacement: 步骤 4 中的图像 1,1
    • Remove the memory module compartment cover.
  5. HP Pavilion dv6-1245dx RAM Replacement: 步骤 5 中的图像 1,3 HP Pavilion dv6-1245dx RAM Replacement: 步骤 5 中的图像 2,3 HP Pavilion dv6-1245dx RAM Replacement: 步骤 5 中的图像 3,3
    • Remove the first memory module by spreading apart the two silver retaining tabs, using your thumb and index finger.
    • Pull and lift the green memory module upward at a 45-degree angle, and then pull the memory module out of the computer.
    • If you are replacing both memory cards, repeat this step with the bottom memory card.
  6. HP Pavilion dv6-1245dx RAM Replacement: 步骤 6 中的图像 1,1
    • To replace the memory card, insert the card at a 45-degree angle, then push into slot.
    • Push down gently so the silver retaining tabs click back into place.
    • If you are replacing both memory cards, replace the bottom card (closest to the system board) first.
结论
4等其他人完成本指南。
Jaime
于01/23/14注册
562 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 18
总计 2,375
